Finding Electric Field on rod or ring?
The discussion focuses on calculating the electric field at a point P along the axis of a uniformly charged rod of length l and total charge Q. The electric field is derived using the formula E = (integral) from a to l+a of ke lambda dx/x^2, where ke is Coulomb's constant and lambda is the charge per unit length. The confusion arises from the integration process and the transition to the final expression E = keQ/a(l+a), which is clarified through the anti-derivative of 1/x^2. The example illustrates the mathematical steps needed to arrive at the correct formula for the electric field.
  • Understanding of electric fields and Coulomb's law
  • Familiarity with calculus, specifically integration techniques
  • Knowledge of charge distribution concepts, particularly linear charge density
  • Basic understanding of the relationship between charge, length, and electric field
  • Study the derivation of electric fields from continuous charge distributions
  • Learn about the application of integration in physics, particularly in electromagnetism
  • Explore the concept of electric fields from different geometries, such as rings and disks
  • Practice problems involving the calculation of electric fields using various charge configurations
Students of physics, particularly those studying electromagnetism, educators teaching electric field concepts, and anyone seeking to understand the mathematical derivation of electric fields from charged objects.
Brad_1234
Its from an example in the book, and it doesn't seem to make sense,
A rod of length l has a uniform positive charge per unit length (lambda) and a total charge Q. Calculate the electric field at a point P that is located along the long axis of the rod and a distance a from one end.
So then the example takes a small part of the rod, dx which has charge of dq, and is distance x from point P.
dq = (lambda)dx and dE = ke dq/x^2 or ke lambda dx / x^2
fine so far.
Now the example says we must sum up the contributions of all the segments.
it becomes an integral E = (integral) from a to l+a of ke lambda dx/x^2
the example breaks the dq component out into ke lambda [ - 1/x ] from a to l+a I am somewhat confused now.
then it goes on, ke lambda(1/a - 1/l+a) = keQ/a(l+a) ? what??!
okay it kind of makes sense, the total charge divided by length, but the last part there is a divide by zero error to my thought process, multiplying an item with example values: Lambda(1/a - 1/b) or Q/l(1/a - 1/b) might give (Q/l * 1/a) - (Q/l * 1/b) if doing the same thing for the actual values, should give Q/la - Q/la + l^2 ?? no?
reducing it down to Q/a(a+l) ? the book doesn't explain how it arrived at this.
Can anyone give an example of calculating the Field from a charged rod? apparently its the same in a ring from the x-axis but using vectors, but this concept seems tough, thanks for any explanations
I assume you understand and agree that that's the total field at the point in question.
What's the anti-derivative of [itex]1/x^2[/itex]? That's where the [itex]1/x[/itex] comes from.
[tex]k\lambda (\frac{1}{a} - \frac{1}{(l + a)}) = k\lambda (\frac{l+a}{a(l+a)} - \frac{a}{a(l+a)}) = k\lambda l \frac{1}{a(l+a)} = \frac{k Q}{a(l+a)}[/tex]
  • · Replies 25 ·
  • · Replies 18 ·
