Big Spinning Ball Question (Confused)
by obiwanjabroni
Tags: ball, confused, spinning
obiwanjabroni
obiwanjabroni is offline
#1
Dec15-05, 03:46 PM
P: 1
Hi, so a friend and I had a question a few days ago and we don't know what will happen.
So, let's say that there's an infinitely rigid ball that's very large (so it doesn't deform and so that the tangential velocity at different radii are noticeably different).
Now, let's say this ball were rotating such that a point on the surface of the sphere were moving at 0.9999. What kind of forces would be on the ball? Would it just be shearing forces to different "slices" of the ball? How would a point on the surface with a greater radii and a point on the surface with lesser radii see each other?
Thanks in advance!
Phys.Org News Partner Science news on Phys.org
SensaBubble: It's a bubble, but not as we know it (w/ video)
The hemihelix: Scientists discover a new shape using rubber bands (w/ video)
Microbes provide insights into evolution of human language
pervect
pervect is offline
#2
Dec15-05, 08:14 PM
Emeritus
Sci Advisor
P: 7,443
Quote Quote by obiwanjabroni
Thanks in advance!
I've only seen the non-relativistic case analyzed for the forces (stresses), and that for a cylinder, not a sphere. In that (non-relativistic cylinder) case, you have both radial stresses, and tangential stresses both of which are in the form of tensions.
see for instance
http://arxiv.org/abs/physics/0211004
There is also a bare statement of the above results at
http://www.dow.com/sal/design/guide/flat-disks.htm
for the classical rotating cylinder, mainly of interest because it is concicise which appears to duplicate the above (non-relativistic) results.
The radial stress term goes to zero as r->R, but there is still a large tangential stress.
The quantity v, "Poisson's ratio" is about .28 for steel. Steel, of course, would never be strong enough to rotate at such relativistic velocities (but no material known to man would be strong enough either).
Register to reply
Related Discussions
Ball spinning around a rod.. Introductory Physics Homework 1
A spinning ball hits a wall and bounces back question Advanced Physics Homework 14
Spinning Ball Introductory Physics Homework 4
Spinning ball Introductory Physics Homework 2
Colliding with a spinning ball: linear momentum question Classical Physics 6
