| Thread Closed |
compatibility of qunatum measurements |
Share Thread | Thread Tools |
| Dec16-05, 05:41 PM | #1 |
The question is "two operators A,B do not commute". Is it true that
([A,B]psi) does not equal zero for any state psi?" I'm not sure if there are any cases in which a state psi could produce this result (except for the obvious one where psi = 0 and there is no particle). Thanks |
| Dec16-05, 06:20 PM | #2 |
Recognitions:
Here is a hint: think about the commutator [tex] [x^2 , p] [/tex]. Can you find a state that gives zero when you hit it with the commutator even though commutator isn't identically zero?
| Dec17-05, 04:39 PM | #3 |
I've tried applying the commutator to an arbitrary psi and i get i*h bar * 2x* psi. The only case where I can think of this equalling zero is when psi = 0, which is the obvious case of having no particle.
| Dec17-05, 04:41 PM | #4 |
Recognitions:
You can't think of any state that gives zero when you hit it with the position operator? Hint: think about position eigenstates.
| Thread Closed |
| Thread Tools | |
Similar Threads for: compatibility of qunatum measurements
| Compatibility, H2 embrittlement | Materials & Chemical Engineering | 0 | ||
| [SOLVED] Qunatum Angular Momentum | Advanced Physics Homework | 6 | ||
| Qunatum Mechanics Help me !.. | Academic Guidance | 3 | ||
| Compatibility | Medical Sciences | 31 | ||
| Electromagnetic compatibility | Electrical Engineering | 0 | ||
