Projectile Speed Comparison: Explaining with No Equations
  • Thread starter Thread starter amcavoy
    Projectile
The discussion revolves around a problem in projectile motion, specifically comparing the landing speeds of two objects launched from the same height but at different angles. The original poster is exploring whether the final speeds of the two projectiles, fired at angles θ and 2θ, will be the same despite differing velocity vectors.
  • Exploratory, Conceptual clarification
  • The original poster attempts to justify their belief that the speeds will be the same by considering the conservation of energy, while seeking ways to explain this without resorting to equations. Some participants suggest that energy conservation principles could support this reasoning.
Participants are actively engaging with the concepts of energy conservation and its implications for the problem. Some guidance has been offered regarding the use of energy principles, and there is a recognition that the original poster's reasoning aligns with these concepts, though no consensus has been explicitly stated.
The original poster is constrained by the requirement to explain their reasoning without using equations, which adds a layer of complexity to their justification.
amcavoy
If two objects are fired, both from a height h and speed v0, where object A is fired at an angle θ with the horizontal and object B is fired at an angle of 2θ, which will land with a greater speed?
It seems to me that the speed would be the same for both, although the velocity vectors would differ in their x- and y-components. Is my answer correct? The question asks to explain this without any equations, so I am having trouble justifying it. Any ideas? Thank you.
HINT: Energy is conserved! :)
So if I use y=0 as my reference point and y=h as the launching point, I can say that:
Object A:
[tex]mgh+\frac{1}{2}m{v_{0}}^{2}=\frac{1}{2}m{v_{A}}^{2}[/tex]
Object B:
[tex]mgh+\frac{1}{2}m{v_{0}}^{2}=\frac{1}{2}m{v_{B}}^{2}[/tex]
Then vA must equal vB. Is this correct?
Yes, and you can even say that without using equations! :)
  • · Replies 18 ·
