If power were applied to a one meter cube of quartz crystal
Applying power to a one meter cube of quartz crystal will produce gravitational waves that are orders of magnitude too weak to be detected. Albert Einstein confirmed that quartz crystals do not radiate significant gravitational waves. According to MTW's "Gravitation," the power radiated in gravitational waves can be calculated using the formula P_gw = P_int^2 / (3.63*10^52 ergs/sec), where P_int represents the internal power from the crystal's vibrations. Given that 3.63*10^52 ergs/sec equates to 200,000 solar masses * c^2, the gravitational waves emitted by quartz crystals are negligible.
  • Understanding of gravitational wave physics
  • Familiarity with Albert Einstein's theories
  • Knowledge of energy conversion in physics
  • Basic concepts of quartz crystal properties
  • Research gravitational wave detection methods
  • Study the principles of energy radiation in materials
  • Explore the implications of Einstein's theories on modern physics
  • Investigate the properties and applications of quartz crystals in technology
Physicists, engineers, and students interested in gravitational wave research, as well as those studying the physical properties of materials like quartz crystals.
NeedBioInfo
Is it true that, if power were applied to a one meter cube of quartz crystal and the crystal were driven to the breaking point, the gravity waves produced would definetly, 100%, be orders of magnitude too weak to be detected?
Apparently Albert Einstein calculated that
Yes, we can be sure that quartz crystals do not radiate much in the way of gravitational waves.
For instance, check out MTW's Gravitaiton, pg 978. Converting the formulas in the text into standard units, the power radiated in gravitational waves will be approximately
where P_int is the "internal power", which is the kinetic energy stored in the vibration of the quartz crystal.
Because 3.63*10^52 ergs/sec is 200,000 solar masses * c^2 worth of energy per second, we can safely say that the amount of gravitational waves radiated from a quartz crystal is very small.
  • · Replies 0 ·
  • · Replies 45 ·
10K
