| Thread Closed |
wisdom teeth? |
Share Thread | Thread Tools |
| Dec19-05, 05:58 AM | #1 |
wisdom teeth?
Is it necessary to take a human's wisdom teeth out?
| Dec19-05, 07:50 AM | #2 |
Only if they are somehow bad, or you mouth hasen't enough room for them.
| Dec19-05, 03:10 PM | #3 |
I feel fine with them but the dentist thinks I should take them out because they are hard to clean. Is that good enough reason to take them out?
| Dec19-05, 09:27 PM | #4 |
wisdom teeth?
You may be interested in reading an earlier biology thread on wisdom teeth.
Must wisdom teeth come out? This reference points to 4 situations where they recommend having them removed: [1] when impacted, [2] if you are prone to pericoronitis (infection of the gum near a partially erupted wisdom tooth),[3] if they are coming in the wrong position (making cleaning difficult) and [4] when they are opposite an already pulled wisdom tooth. Note that one of these reasons does recommend pulling them when they are difficult to clean. If they cannot sufficiently clean off the plaque (bacteria), you will be more prone to gingivitis. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: wisdom teeth?
| Your experience with wisdom teeth | General Discussion | 26 | ||
| Wisdom teeth! | General Discussion | 22 | ||
| 6 wisdom teeth!!!11 | General Discussion | 39 | ||
| Teeth | General Discussion | 23 | ||
| Wisdom Teeth | Biology | 7 | ||
