What are As precipitates and As antisites in a GaAs sample?
  • Thread starter Thread starter armandowww
The discussion focuses on arsenic (As) precipitates and antisites in gallium arsenide (GaAs) samples, particularly those grown at low temperatures with an annealing process. It is established that As antisites occur when arsenic atoms occupy positions meant for gallium atoms, while As precipitates form when excess arsenic atoms cluster around defects in the crystal structure. The presence of these defects alters the electronic properties of GaAs by introducing energy levels within the bandgap. The zincblende structure of GaAs, characterized by a 1:1 ratio of gallium to arsenic atoms, is crucial to understanding these phenomena.
  • Understanding of zincblende crystal structure in semiconductors
  • Knowledge of low-temperature growth techniques for GaAs
  • Familiarity with annealing processes and their effects on crystal defects
  • Basic concepts of electronic properties in semiconductor materials
  • Research the effects of dopants on As precipitates in GaAs
  • Learn about the annealing process and its impact on crystal defects in semiconductors
  • Explore the electronic behavior of GaAs with varying As antisite concentrations
  • Investigate the role of dislocations in the formation of As precipitates
This discussion is beneficial for materials scientists, semiconductor researchers, and engineers involved in the fabrication and optimization of GaAs-based devices, particularly in understanding defect-related phenomena in crystal growth.
armandowww
What are As precipitates and As antisites in a GaAs sample? Being more specific, my material is low temperature grown with an annealing process.
Thanks anyway
You might wish to look into buying this article.
Dislocations and precipitates in gallium arsenide
http://scitation.aip.org/getabs/servlet/GetabsServlet?prog=normal&id=JAPIAU000071000002000620000001&idtype=cvips&gifs=yes
Gallium arsenide single crystal solar cell structure and method of making - United States Patent 4370510 - maybe some useful background. One can download or view tiff files of the patent, or browse html online.
Search by patent number - http://patft.uspto.gov/netahtml/srchnum.htm
As precipitates will also depend on dopants and other impurities. I have seen reference to arsenates, which seems to imply oxygen, which I presume is an impurity.
I know I'm bumping an older thread, but here goes.
Simply put, a GaAs crystal consists of alternating Ga and As atoms (actually two interpenetrating fcc sublattices called a zincblende, ZnS, or sphalerite structure) such that there is a 1:1 ratio of Ga to As atoms. For a variety of reasons that we can get into, when you grow GaAs at low temperature you tend to end up with slightly more arsenic atoms than gallium atoms in the crystal. The question is where do the arsenic atoms go?
Three places. They go 1) where they're supposed to go 2) where gallium is supposed to go 3) in between the other atoms (interstitials)
An As antisite is when an arsenic atom shows up where a gallium atom is supposed to be. An As precipitate is when the excess As atoms cluster together, usually around an existing defect (dislocation) in the crystal. This precipitation can occur when the As atoms diffuse during the annealing process.
The reasons for this can be quite specific to the particular method used for growing the crystal. The result is generally the same: the appearance of As atoms in positions they aren't "expected" to be in changes the electronic behavior, usually by introducing energy levels within the bandgap.
  • · Replies 0 ·
17K
