Whats wrong with this free energy experiment
The discussion revolves around a proposed free energy experiment involving a balance designed to demonstrate movement caused by gravity without lowering the center of mass. Participants explore the validity of the experiment and the underlying physics principles.
  • Experimental/applied
  • One participant describes an experiment using a wooden beam with weights at each end, claiming that the center of mass (CoM) is at the axis and that the balance behaves differently than expected based on traditional physics.
  • Another participant questions the validity of the experiment, referencing previous examples of misunderstood physics and suggesting that the balance should be stable if the CoM is at the axis of rotation.
  • A different participant argues that experimental data contradicts established physics, expressing frustration with the acceptance of traditional views and inviting others to reproduce the experiment.
  • Concerns are raised about the clarity of the original poster's explanations, with a request for more coherent communication regarding the experiment's setup and results.
  • One participant critiques the original poster's understanding of physics, suggesting that their lack of clarity undermines their arguments and calling for a more rigorous approach to discussing the experiment.
Participants express disagreement regarding the interpretation of the experiment and its implications for established physics. There is no consensus on the validity of the claims made by the original poster or the conclusions drawn from the experiment.
Some participants note potential misunderstandings in the terminology used, such as the use of "axe" instead of "axis." There are also indications that the original experiment may have overlooked certain physical principles, but this remains unresolved.
Readers interested in experimental physics, debates on free energy concepts, and discussions surrounding the interpretation of physical principles may find this thread relevant.
eosphorus
my objective was that gravity caused movement in an object without lowering the center of mass
i built a balance that has the center of gravity in the axe:
i used a 60 cm long 1 cm thick wood beam, i put a nail in the middle as an axe,
i put 100 grams of plastiline in each end of the beam
first try the CoM was lower than the axe what would be noticed because turning upside down the beam it wouldn level
the way to make sure the CoM is in the axe is by trying the balance normal and upside down
ive noticed it even has a period which by the way i was given here and deppends on the mass and length of the beam not how low the CoM is from the axe as is the case of a pendulum
my next step is freezing the plastiline to make sure the CoM is not lowered by the weight
anny suggestion of what I am doing wrong or how this is posible?
What's the obsession with "free energy"? Every single one of your examples so far--the yo-yo, the lop-sided balance, the tetherball--has been shown to have been based on a misunderstanding of the physics involved. What makes you think that your balance is any different?
As usual, it's unclear what you are trying to accomplish. Note: If a rigid body has its center of mass exactly at the axis of rotation that supports it, then it will be stable in any position.
physics has always been far to describe how nature works there are always corrections, if it wasnt this way the Earth would still be said to be flat
im not claiming on ideas I am claiming on facts, i built a balance that levels with the center of mass in the axe, anybody can reproduce this
you say it won't level because physics say so, i disagree because I've experimented it
now if physics say one thing and experimental data say the opposite what's the conclusion
my conclusion is that as long as people believes blindly what they are taught mothers will see their kids starve to death(from here comes my obsesion with free energy) because things are too complex to be changed then
you say an object with the center of mass in the axe won't move, I've experimented a balance with the center of mass in the axe will move and i welcome anybody to reproduce the experiment
just my two cents
What is your native language? some of what you say does not make sense - when you say axe, do you mean axes? (x.y,z axes?).
I agree with you that it is not good to blindly accept all of physics, but you need to explain yourself more clearly. Do not forget that it is *possible* that you overlooked something in your experiment. Try and explain the experiment fully and see what people say about the physics...
You have no ability to say that when you are ignorant of physics. You should follow your own advice and stop making judgement calls on things you haven't not understood in the first place.
And please don't ask us to EXPLAIN what you did when you cannot even state what you are doing in a clear and coherent manner. This has been an ongoing pattern of your post and I have seen zero improvement at all. This has the earmark of going down the path of all your other posts, i.e. nowhere.
Please refrain from starting one of these types of threads again.
Zz.
  • · Replies 77 ·
  • · Replies 48 ·
  • · Replies 138 ·
9K
  • · Replies 35 ·
  • · Replies 22 ·
