Gah What's wrong with my ears :*(
  • Thread starter Thread starter moose
The discussion revolves around a participant's experience with unusual ear sensations following a cold, specifically after blowing their nose. Participants explore potential causes, including ear infections and pressure changes in the ear, while sharing personal anecdotes and advice.
  • One participant describes experiencing a loud noise and pressure sensation in their ear after blowing their nose, which has occurred multiple times.
  • Another participant suggests that the issue may be related to a structural defect in the sinus cavities, questioning whether the original poster has narrow nasal passages.
  • Several participants propose that the symptoms could indicate an ear infection, with some sharing personal experiences of having had multiple ear infections.
  • Some participants express skepticism about the possibility of an ear infection, noting the absence of pain and other common symptoms associated with infections.
  • One participant theorizes that the sensation may be due to pressure differences between the middle ear and the atmosphere, suggesting that blowing the nose can cause the eardrum to bend and release pressure.
  • Another participant mentions the Eustachian tube's role in equalizing ear pressure and suggests remedies like chewing gum or yawning to alleviate symptoms.
  • Some participants humorously suggest extreme or impractical methods to address the issue, such as using unconventional objects to probe the ear.
Participants do not reach a consensus on the cause of the symptoms. While some lean towards the idea of an ear infection, others argue for pressure-related explanations. The discussion remains unresolved with multiple competing views.
Participants mention various symptoms and conditions related to ear health, but there is no agreement on the specific diagnosis or necessary actions. The discussion includes anecdotal evidence and personal experiences without definitive conclusions.
Individuals experiencing similar ear sensations, those curious about ear health, or anyone interested in discussions about common cold-related symptoms may find this thread relevant.
moose
For the past week and a half or so, I've had a cold. I've had an extremely runny nose the entire time, like always. Well, two days ago, I went to blow my nose and all of a sudden there was a weird noise in my right ear, and it felt like air came out of my ear :rolleyes: . It kinda felt like when your ears pop, except amplified * 100. That day I didn't hear as well out of my right ear for an hour or so, and then everything was normal, so I didn't think much of it. And now, today, the same thing happened three times. However, today it didn't make me hear any worse, but it just feels weird O_O. Also it sounds weird o_O... Anyone had this happen to them?
Biology news on Phys.org
I can't blow my nose for that very reason. As far as I know, it's a structural defect in the sinus cavities. Do you happen to have very narrow nasal passages?
Possibly an ear infection?
I don't know O.O This has never happened before o.0
Most likely an ear infection.
I've had lots of ear infections in my lifetime. :frown:
That happens to me sometimes too when I blow my nose really hard. I dunno.. my ears still work.
That's unfortunate. My brother use to have ear infections when he was little and by the crying and screaming, I can only imagine that they were very unpleasant.
Yeah, it starts to hurt if you wait too long to do anything about it.
Leaving it for any longer than 2 weeks can make it pretty bad. You can even lay your head down to sleep sometimes. :eek:
I've never had an ear infection... in my life...
How do you know if you have an ear infection? I really doubt I do, because my ear does't hurt whatsoever...
Some ear infections can go away on its own.
It's possible that you never got one yet.
Me neither... Wonder why some people have healthy ears and some don't.
I've heard that breast-fed babies are less likely to have ear infections.
Speaking of things I've never had :rolleyes:
I've never had a nose bleed in my life...
EDIT:
* Swelling, heat, or tenderness around or behind the ear.
* Redness of the ear, ear canal, or skin around or behind the ear.
* Drainage from the ear that does not appear to be earwax.
* Itching of the ear or ear canal.
* Fever.
Yeah, I don't have any of those symptoms.
I really don't think it's an ear infection. I've never had an ear infection and I've have that happen to me all the time. My guess is that it's caused by the difference in pressure between your middle ear and the atmosphere. When you blow your nose, you increase the pressure in your middle ear, so your ear-drum bends to create an opening and the pressure normalizes (or if you keep blowing, the air streams out). It's not a good idea to do that though since a lot of ear infections start when bacteria from mucus goes into your middle ear via the explained method.
Do not listen to anyone here!
Go see a doctor and ask him/her!
I think this is probably right. Under normal circumstances I don't believe there is any continuous passage from the sinuses out the ear. On the other hand I have read that there are places in there where excess gas can build up and has to vent occasionally. This explained why, every once in a while I'll hear a very high pitched whistling noise in one ear that attenuates till it is no longer audible.
EDIT:
Um... you can still have an inner ear infection.
I had the same problem as you about a month ago, and it was an inner ear infection. I had none of those symptoms either. The fluids remained in my ear, so it did not leak out, like it should.
You have a little tube called the Eustachian tube, that runs from the back of your middle ear to your nose. Its function is to ventilate the middle ear, makeing sure that the pressure inside the ear remains at near normal air pressure. It also drains any accumulated secretions, infection, or debris from the middle ear space.
When you blow your nose hard, these tubes may become pluged, causeing things to sound muffled. Your cold is more then likely the cause, and you can try chewing gum or yawning really big to help clear the tubes.
And as noted by Matt, check with your doctor.
I hope its not like the time I really tried to push a fart out. Was there any discharge??
Take up smoking and see if you can blow smoke out your ear. you could probably make a fortune in bars if you can.
Could be a ruptured eardrum.
Go see a doctor!
This is the only advice you should be listening to here, along with Astronuc's post just above telling you the same thing. It'll take a fairly short visit to the doctor for them to look in your ear and determine if there's an infection, a ruptured eardrum, some sort of blockage that's not draining properly and might lead to an infection, or something else entirely. Especially if it's recurring, you should get it checked out. Something is obviously wrong, but nobody can tell you without actually looking at your ear.
I'd try seeing how far you can get a Q-Tip into your ear canal then have someone look for the cotton tip in your nostril.
I have these ke-bab skewer things. I bet you could use one to push a Q-tip all the way through.
Would you be willing to Fed Ex one to moose? Might be a couple of days til you get it back though. I've tried pencils, car antennas, shots of air from a compressor, and a vacuum to the nostril and I can't get a Q tip more that 3/4 of the way down my Eustachian.
I'm normal! Hurray!
you are more than normal. Super normal, no , Ultra, no, oh yeah, you are more than normal you are AB normal!
I'm extra-ordinary!
Go to the doctor, or this will happen to you!
It's such a worthy cause I can't really refuse can I?
Or, he could run down to the local Chinatown market and get a bag of 100 for 99 cents.
That attachment Evo posted, that might be a good look for moose. He should at least try it before deciding.
  • · Replies 35 ·
