CD/DVD Burner Not Burning - Troubleshooting Help
  • Thread starter Thread starter Homer Simpson
The discussion revolves around troubleshooting a malfunctioning CD/DVD burner that is unable to burn discs, despite being able to read and play them. Participants explore potential hardware and software issues, as well as the possibility of defective media.
  • One participant suggests that the issue is likely hardware-related, while another mentions the possibility of a corrupted driver or registry file causing the problem.
  • Some participants propose that the error message 'focus or tracking error' indicates a laser issue, while others argue it may be a generic error that could stem from various causes.
  • There are repeated suggestions to test different batches of CDs, as one participant speculates that the problem could be due to using a single bad batch of discs.
  • A participant shares a personal experience of a CD-ROM failure, indicating that hardware can fail unexpectedly.
  • Another participant humorously suggests extreme measures, like smashing the unit, to resolve the issue, while also mentioning the potential for lens obstruction affecting performance.
  • There is a mention of needing better CD burner software and testing software for the CD/DVD driver.
Participants generally agree that the issue is likely hardware-related, but there is no consensus on the exact cause or solution. Multiple competing views regarding the nature of the error and the potential for software issues remain unresolved.
Some participants note the limitations of generic error messages and the potential for various underlying issues, including hardware wear and media quality, but do not resolve these uncertainties.
Homer Simpson
CD/DVD burner fried??
Hi all,
My CD/DVD burner won't burn anymore. It still reads and plays discs no problem, however when using NERO or windows Media Player to try and burn a disc it gives errors before even starting.
NERO error : 'focus or tracking error'
I hardly use the burner. Question is whether this is a Hardware problem and I need a new player/burner or possibly a software problem as my computer has so much crap on it, including multiple player/burner programs?
Thank you in advance.
Computer science news on Phys.org
It's a hardware issue.
As Morbid Steven mentioned, it is likely a hardware issue, although a corrupted driver or registry file could also cause a problem.
One way to confirm a hardware problem is to uninstall it, remove the hardware, turn on the PC to make sure the hardware is uninstalled, turn off the PC, and reinstall the hardware and let Windows Plug n' Play reinstall it. If it still doesn't work, it is more than likely hardware and time to get a new CD/DVD RW/burner. Stochastically, some components will wear out well before their design lifetime or design half-life.
Have u tried a different batch of CD's?
It sounds like a hardware error, it could also be a cd error rather than the CD burner itself, as u stated u don't use the burner much.. maybe u have only used 1 batch of cd's that were bad
This is very much incorrect.
"focus or tracking error" refers to an issue with the laser. Use google to find more information.
:confused: :confused:
That is a GENERIC error message, that is stating the laser cannot Focus or Track.. which could mean that it cannot find the start point on a CD to start Burning!
Error messages are Generic typically.. Bar Cisco ones :-p
I actually had a CD-ROM that fried. I smelled burning coming from the inside of my PC and when I tried to eject the tray, it wouldn't. It was about 3 years old at the time and I guess it worked to its limits. I had to buy a replacement (DVD burner).
Thanks for the replies guys. I have tried a few different cd disc types and different speeds (havent got any blank DVD's handy). No luck. I think I'll try smashing the unit with a hammer and see how that works out. It might effect its playback ability but on the whole I think it would benifit me.:devil:
Have you checked for "fluff" on the lense? This could also stop the laser from reading the disk correctly? After say that tho, i would think that you would not be able to play disks also if that was the case...
I would suggest adding a railroad spike for maximum healing.
Or you could summon the old gods in a psuedo-nordic ritual to try and heal the laser. I'm sure Odin or Thor would have some knowledge of electronics.
