How do you create chemical equation?
  • Thread starter Thread starter gomani
    Chemical
The discussion centers around the creation of chemical equations, focusing on the structure and balancing of these equations in the context of chemical reactions. Participants explore both the theoretical aspects and practical examples of writing chemical equations.
  • Homework-related
  • One participant explains that a chemical equation consists of reactants and products, emphasizing the need to know both to create an accurate equation.
  • Another participant provides an example of the reaction between hydrogen and oxygen to form water, detailing the importance of balancing the equation with coefficients.
  • A different participant describes the general structure of a chemical equation, noting the placement of reactants and products, and introduces the concept of oxidation numbers in balancing equations.
  • There is mention of the complexity involved when polyatomic ions are included in chemical equations, suggesting that further research may be necessary for clarity.
Participants provide various explanations and examples of creating chemical equations, but there is no explicit consensus on a single method or approach. The discussion remains exploratory with multiple perspectives presented.
Some participants reference the need for understanding oxidation numbers and the complexity introduced by polyatomic ions, indicating that additional assumptions or definitions may be required for a complete understanding.
gomani
Chemistry news on Phys.org
A chemical equation describes what is occurring in a chemical reaction and is made up of two parts, the reactants and the products. To create a chemical equation you need to know what is going into the reaction as that will determine what, and how much, is going to be produced. Sometimes you can combine things together many different ways and produce many different things (Hydrocarbons are a perfect example), so it is also a good idea to know the end result of the reaction too.
Take Hydrogen gas (H2) and Oxygen gas (O2), If you react these together you will make water,
H2 + O2 --> H2O
But there is a catch, water has twice as many Hydrogen atoms in it per molecule as it does Oxygen, so it should require twice as much Hydrogen gas as Oxygen gas. To balance this equation, we put coefficients infront of certain substances,
2H2 + O2 --> 2H2O, this was there are 4 Hydorgen atoms and 2 Oxygen atoms on each side.
Perhaps this will also be of some help,
http://en.wikipedia.org/wiki/Chemical_equation
thank you very much
chemical equation is an expression representing a chemical reaction; the formulas of the reactants (on the left) are connected by an arrow w/ the formulas for the products (on the right).
reactants-------> products (this is the structure of a chemical equation)
Fe + O2-----> Fe2O3
Fe (iron) has an oxidation # of 3 & O2 (oxygen) has an oxidation # of 2... you just have to exchange them in places... but not in a superscript form... put them in the bottom (subscript) of the symbol of the element...
there are also polyatomic ions that if you're going to make them as a chemical equation, it's more complex... just type chemical equation in the google & you can understand better on what I've said... good luck...
  • · Replies 46 ·
