Photo electric effect relate to determining the charge of an electron?
The discussion revolves around the relationship between the photoelectric effect and the determination of the charge of an electron. Participants explore the principles of the photoelectric effect and its implications for measuring charge.
  • Participants discuss the mechanics of the photoelectric effect and its formula, questioning its relevance to charge determination. Some express uncertainty about applying the photoelectric effect to calculate the charge of an electron, while others reference the Millikan Oil Drop Experiment as a classical method for this measurement.
The discussion is active, with participants sharing different perspectives on the relationship between the photoelectric effect and charge determination. Some guidance is provided regarding the classical methods for measuring charge, but no consensus has been reached on the connection to the photoelectric effect.
There are mentions of potential controversies regarding historical experiments, specifically the Millikan Oil Drop Experiment, which may influence the discussion on the reliability of charge measurements.
Kristine
how does the photo electric effect relate to determining the charge of an electron?
I'm not sure that it does.
The photoelectric effect is where incident photons have sufficient energy to knock electrons out of their captured state - ie ionise the material. Charge is irrelevant here.
If we apply formula for Photoelectric effect i.e.
[tex]k_{max}=E_{photon}-\phi(work function of metal)[/tex]
now if we are able to stop the fastest moving electron with cuttoff voltage such that [tex]eV_0 = K_{max}[/tex]
so we can calculate e from above equation
But I'm not sure whether this is applied for charge calculation
The classic experiment for determination of electron charge is the Milliken Oil Drop Experiment. Or, as I call it, the Milliken Eye-strain Experiment.
Njorl
Yes its true classical method was developed by Milikan
But i read somewhere that he manipulated with his readings , is there any controversy
  • · Replies 22 ·
