Solving a Differential Equation Conflict
  • Thread starter Thread starter gulsen
The discussion revolves around solving a basic differential equation of the form dy/dx = x + y with an initial condition y(0) = 1. Participants explore different methods to solve the equation, including attempting to make it exact and treating it as a non-homogeneous equation.
  • Mixed
  • Some participants attempt to solve the equation by making it exact, while others question the correctness of this approach. There is also discussion about solving it as a non-homogeneous equation and the implications of integration constants.
Participants are actively engaging with the problem, providing corrections and clarifications regarding the methods used. There is recognition of errors in the initial attempts, particularly concerning the integration constant and the naming conventions of solutions.
Some participants note the importance of initial conditions and the role of arbitrary constants in the solutions. There is also mention of potential typos in the original equations presented.
gulsen
I have a basic differential equation:
[tex]\frac{dy}{dx} = x + y, y(0) = 1[/tex]
Now, when I try to solve this by making it exact
[tex]\mu \frac{dy}{dx} + \mu y = \mu x[/tex]
I get [tex]\mu = e^{-x}[/tex] and solution [tex]-x-1[/tex]. This doesn't satisfy the initial condition. But when I try to solve it as a non-homogenous equation as:
[tex]\frac{dy}{dx} + y= x[/tex]
I get
[tex]y_p = 2e^x, y_c = -x-1[/tex]
so
[tex]y = 2e^x-x-1[/tex]
Which seems to be a correct & full solution. What was I missing in the first try?
You are solving dy/dx + y = x which is wrong since the original equation is
dy/dx = x + y, or dy/dx - y = x so now u(x) = e^(-x) and so on and it works out.
And yes, the answer is y = 2e^x - x - 1
I assume this was just a typo, but that equation should be
[tex]\mu \frac{dy}{dx} - \mu y = \mu x[/tex]
Your error: you forgot the constant of integration. You should have obtained
[tex]y = -(x+1) + c/\mu = ce^x - (1+x)[/tex]
and then solved for the initial condition [itex]y(0)=1[/itex] yielding [itex]c=2[/itex] or
[tex]y = 2e^x -(x+1)[/tex]
I get
so
You're nomenclature is backward here. The solution to the homogeneous equation is called the complementary function and is denoted as [itex]y_c[/itex]. The complementary function generally involves arbitrary constants. A solution to the inhomogeneous equation is called a particular function and is denoted as [itex]y_p[/itex].
In this case, the solution to the homogeneous equation [itex]y^\prime-y=0[/itex] is
[tex]y_c = ce^x[/tex]
where [itex]c[/itex] is an arbitrary constant and
[tex]y_p = -(x+1)[/tex]
is a particular solution to the inhomogeneous equation. Combining these,
[tex]y = ce^x - (1+x)[/tex]
which meets the initial conditions when [itex]c=2[/itex].
Oh, that was just a typo. Thanks D_H, it ends up that I've forgotten the integration constant.
About naming, take it easy, I'm just a freshman!
  • · Replies 24 ·
