Why is the Tractor Backwheel Larger than the Forewheel?
  • Thread starter Thread starter sachin_himcs
The discussion revolves around the design choice of having larger back wheels compared to front wheels on tractors. Participants explore various reasons for this design, including functionality in different terrains, weight distribution, and historical design choices.
  • Some participants suggest that larger back wheels improve performance in mud and soft ground by providing better flotation and reducing the tendency to dig in.
  • Others argue that larger back wheels are more efficient for torque transfer to the ground, especially at the slow speeds typical of tractor operation.
  • It is noted that the rear wheels bear most of the load when towing, while the front wheels primarily serve for steering.
  • Some participants mention that modern tractors often have the same size wheels across all axles, particularly in 4WD or 6WD models, which differ from traditional designs.
  • There is a discussion about the design aesthetics of tractors, with one participant humorously noting that tractors would look odd with larger front wheels.
  • Historical references to tricycle tractors are made, with participants sharing personal experiences and discussing their advantages in terms of turning radius.
  • Concerns are raised about the stability of tricycle tractors, especially on slopes, and the necessity of safety features like roll cages.
Participants express a range of views on the reasons for the design of tractor wheels, with no clear consensus reached. Some agree on certain functional aspects, while others introduce differing perspectives, particularly regarding modern versus traditional designs.
Participants reference various types of tractors and their uses, indicating that the discussion may be influenced by specific contexts such as farming versus construction. The historical context of tricycle tractors and their design limitations is also noted.
Individuals interested in agricultural machinery design, tractor functionality, or historical agricultural practices may find this discussion relevant.
sachin_himcs
sir
I want to know the reason.
why tractor backwheel larger then forewheel ?
thanks
Two reasons I can think of:
1. The larger tires are better in mud and soft ground. Smaller tires would have a greater tendency to dig into soft earth.
2. A more efficient means of transferring torque to the ground especially at slow speeds which is where tractors usually operate.
And just thinking out loud here, I'm not quite sure on this...
If a tractor has to tow something, the rear wheels will take the brunt of the load. The front tires will be for steering only.
Hi guys. Fred's got it pretty much covered.
A lot of large new tractors are 4, 6 or 8-wheel drive (4 driving axles with 1 or 2 wheels each). On that type, they're all the same size.
The smaller 2WD ones are still all-terrain devices, and therefore need both the 'floatation' effect and the massive lugs. The large area of weight distribution aids in staying on top of mud and soft soil, so as to avoid either getting stuck or causing too much disruption of the ground. While spreading fertilizer, for instance, you don't want to be digging up the crop as you go. As mentioned, most of the weight of a tractor is on the back, so the thin wheels up front don't cause a lot of damage.
I don't know if anyone still makes them, but some of the older jobbies from when I was a kid were almost tricycles. The two front wheels were only a foot or so apart and had massive camber so they formed a downward-facing 'V'.
how about wheel loaders? thay carry the mud/loose Earth on the front bucket, where you have the smaller tires.
Quite true, sree, but they're in a different class. Generally speaking, they're used in mining or construction rather than farm-like conditions. Also, most of them do in fact have the same size of tires all around and the engine and ballast weights are in the back to offset the load.
If you mean the type that are sometimes attached to farm tractors, they don't carry a really significant amount of weight, and are usually only fully loaded when on hard ground. The lifting ability is based upon the centre of mass of the tractor rather than the strength of the hydraulics. If you try to pick up too much, the C of M will be ahead of the front wheels and the tractor will 'nose over'.
Tractors and backhoes also look much better with big back wheels. They'd look ridiculous with big wheels just at the front, and nobody would buy them...
Now there's some real design input![/size]
in reply to danger's comment about the "tricycle" tractors
no one makes them anymore since they would tip over really easily
i used one growing up , it is a Farmall M
the advtange of it though is that it can turn a really sharp radius when you brake only one tire at a time
Hi Brewski. Now I know why Cat was so eager to snap you up from uni. :smile:
Right, Shawn... Farmall. I'd forgotten that brand entirely; was thinking of the little grey Ford. And ours did flop over a couple of times. It also, if I recall, had a tendency to pull wheelies if the plow hit a rock. Not much weight in the front end of one of those things.
Tricycle tractors? Better have a GOOD roll cage when crossing a slope.
No roll cage, but luckily they were very easy to jump off of. :biggrin:
Anyhow, little buggers like that were just used around the farmyard and barns. Any field work pulled the big Case and Oliver into service.
A trike tractor. It doesn't surprise me, but I have never heard of one. You learn something new every day.
Pics of some old John Deere tractors, lots of tricycle style ones:
http://johnnypopper.com/jdletter.shtml
When you see the near tri-cycle tractors race, its even better. Its all about how slow you can go, last to cross the finish line wins! Not as common anymore, but will still happen at a rural fair near July 4th in the midwest.
They really do allow for an incredible turning circle with one rear brake locked. It makes backing up trailers incredibly easy around bends or obstacles. On our farms, we had many Farmalls (I think they later became part of Case-IH) with a "B", "H", W4 and W6. Like the original Jeep, these tractors were designed in an era of easy serviceability by near anyone and incredible durability as an integral part of the DNA.
The ROPS (Roll Over Protection Structure) is sometimes adopted to older tractors, its a big roll bar near the seat, but cost and pride and lack of seat belts mean they are generally only on tractors where they were required for manufacture.
Cool link, Cliff. That do bring up a rememberization or two. :biggrin:
  • · Replies 19 ·
  • · Replies 28 ·
9K
