Temperature Variations of Ideal Gas in Gravitational Field
The discussion centers on how the temperature of an ideal gas varies with height in a homogeneous gravitational field, particularly in a perfectly isolated gas column at equilibrium. Participants explore theoretical implications, thermodynamic principles, and potential contradictions in the behavior of gas under these conditions.
  • One participant questions how temperature varies with height in an ideal gas column in equilibrium, seeking clarification on the behavior of the gas under gravitational influence.
  • Another participant notes that while a thermodynamic system in equilibrium has a single temperature, dividing the gas column into layers suggests differing temperatures due to varying molecular speeds, leading to a perceived contradiction.
  • A third participant introduces the adiabatic atmosphere approximation, suggesting it can be applied in non-extreme situations, and references hydrodynamic equilibrium equations.
  • One participant expresses skepticism about the heuristic nature of the adiabatic approximation and seeks a method to calculate temperature distribution using a referenced article on single-particle distribution in a gravitational field.
  • A later reply presents conflicting views from Coombes and Laue regarding whether temperature remains constant or decreases with height in a thermally equilibrated gas column, citing energy conservation and kinetic energy considerations as factors influencing temperature variation.
Participants express differing views on whether temperature remains constant throughout the gas column or if a gradient exists due to gravitational effects. The discussion remains unresolved, with multiple competing perspectives presented.
Participants highlight potential contradictions in thermodynamic principles and the implications of energy conservation in the context of gravitational fields. The discussion reflects varying assumptions about equilibrium and the behavior of gases in such conditions.
mma
Could somebody tell me, how temperature of an ideal gas varies on height in homogeneous gravitational field in equilibrium?
I mean a gas column perfectly isolated from its environment.
Science news on Phys.org
The interesting in this question is, that a thermodynamic system in equilibrium has only one temperature: T=dU/dS, so our gas column has only one temperature.
But, if we divide our gas column into horizontal layers, then considering these layers as thermodynamic systems, they will have different temperatures, because the average speed of the molecules is greater on the lower layers as in the upper ones. It is a necessity, because every molecule moving upward loses from its speed.
On the other hand, neighboring layers are connected with each other thermally, and therefore they must have equal temperature in equilibrium, so we come again to the other consequence, that our system has only one temperature.
This is a contradiction. What is the solution?
In non-extreme situations (i.e. planetary atmospheres), where there is also very little heat conduction, you can use the approximation of the adiabatic atmosphere.
This uses the "adiabatic gas law" for the rate of cooling as the gas expands, plus the usual hydrodynamic equilibrium equations.
See for instance
http://farside.ph.utexas.edu/teaching/sm1/lectures/node56.html
http://daphne.palomar.edu/jthorngren/adiabatic_processes.htm
If you are interested in exotic situations, relativistic effects may become important.
No, thank you, the non-relativistic approach is enough for me. But this adiabatic approximation seems too heuristic for my taste.
I've found an article for the single-particle distribution for an ideal gas in a gravitational field:
http://gita.grainger.uiuc.edu/IOPText/0143-0807/16/2/008/ej950208.pdf"
But how can I calculate the temperature distribution from this?
OK. Then what about this? :
http://www.iop.org/EJ/abstract/0143-0807/17/1/008"
If a vertical column
of an adiabatically enclosed ideal gas is in thermal
equilibrium, is the temperature the same throughout
the column or is there a temperature gradient along
the direction of the gravitational field? According to
Coombes and Laue, there are two conflicting answers
to the above question:
(1) The temperature is the same throughout because the
system is in equilibrium.
(2) The temperature decreases with the height because
of the following two reasons.
(a) Energy conservation implies that every
molecule loses kinetic energy as it travels
upward, so that the average kinetic energy of
all molecules decreases with height.
(b) Temperature is proportional to the average
molecular kinetic energy.
Coombes and Laue concluded that answer (1) is the
correct one and answer (2) is wrong.
What is surprising, that concrete mathematical analysis also shows that (1) is the correct answer in the thermodynamical limit.
Isn't it interesting?
  • · Replies 135 ·
10K
  • · Replies 109 ·
10K
  • · Replies 60 ·
11K
  • · Replies 28 ·
  • · Replies 22 ·
