Solve for x in terms of a, the inequality
  • Thread starter Thread starter whkoh
    Inequality Terms
The discussion revolves around solving the inequality involving absolute values: |x^2 - 3ax + 2a^2| < |x^2 + 3ax - a^2|, where x and a are real numbers, and a is non-zero. Participants are exploring the implications of squaring both sides and the resulting polynomial inequality.
  • Mixed
  • Participants discuss the strategy of squaring both sides of the inequality and the complications that arise from introducing higher powers. Some suggest solving the corresponding equation first and considering different cases based on the signs of the expressions within the absolute values. Others raise questions about the correctness of the squaring step and the resulting polynomial form.
There is an ongoing exploration of the inequality, with some participants providing guidance on how to approach the problem by factoring and analyzing the resulting expressions. Multiple interpretations of the problem are being considered, particularly regarding the handling of absolute values and the implications of squaring the inequality.
Participants note the importance of the values of x where the two sides of the original inequality are equal, as these points help define the intervals for testing the inequality. There is also mention of potential missing terms during the squaring process, which could affect the analysis.
whkoh
Solve for x in terms of a, the inequality:
[tex] \mid x^2 - 3ax + 2a^2 \mid < \mid x^2 + 3ax - a^2 \mid [/tex]
where [itex]x \in \mathbb{R}, a \in \mathbb{R}, a \neq 0[/itex]
Squaring both sides, I get
[tex]x^4 - 6ax^3 + 13a^2 x^2 - 12a^3 x + 4a^4 < x^4 + 6ax^3 + 7a^2 x^2 - 6a^3 x + a^4[/tex]
[tex]12ax^3 - 6a^2 x^2 + 6a^3 x - 3a^4 > 0[/tex]
[tex]4 ax^3 - 2a^2 x^2 + 2a^3 x - a^4 > 0[/tex]
Stuck here. How do I proceed?
I think the best way to deal with a non-linear inequality is to start by solving the corresponding equation: in this case [itex]|x^2-3ax+ 2a^2|= |x^2+ 3ax- a^2|[/itex]. Yes, you can get rid of the absolute value by squaring both sides but that introduces higher powers. There are three possible cases:
1) The quantities inside the absolute values on both sides are non-negative. In that case, the two absolute values are irrelevant: [itex]x^2- 3ax+ 2a^2= x^2+ 3ax- a^2[/itex] which is easy to solve.
2) The quantities inside the absolute values on both sides are negative. In that case, the absolute values are just multiplied by -1. Divide both sides by -1 and you have the same equation as in 1.
3) The quantities inside the absolute values on the two sides have opposite signs. In that case, again since we can multiply or divide by -1, it doesn't matter which side is negative: we have [itex]x^2- 3ax+ 2a^2= -(x^2+ 3ax- a^2)= -x^2- 3ax+ a^2[/itex] which just gives the quadratic equation [itex]2x^2= 3a^2[/itex], also easy to solve.
The point is that the values of x where the two sides are equal separate the intervals on which one side is larger than the other. Choose one value of x in each interval to see whether the inequality is true in that case.
When squaring both sides, you seem to be missing a 9a2x2 on both sides, but it's okay, since they will cancel each other out.
[tex]4 ax ^ 3 - 2a ^ 2 x ^ 2 + 2a ^ 3 x - a ^ 4 > 0[/tex].
This is so far okay. To continue, you should factor it:
[tex]\Leftrightarrow 2a x ^ 2 (2x - a) + a ^ 3 (2x - a) > 0[/tex]
[tex]\Leftrightarrow (2x - a) (2a x ^ 2 + a ^ 3) > 0[/tex]
[tex]\Leftrightarrow a (2x - a) (2x ^ 2 + a ^ 2) > 0[/tex]
Note that 2x2 + a2 is already non-negative, so can you go from here?
Great, thanks for the help!
  • · Replies 17 ·
