Find the result of this integration
  • Context: Graduate
  • Thread starter Thread starter Ali 2
    Integration
The discussion revolves around the integration of the function \(\int_0^\infty \frac { e^{-3x} - e^{-4x} }{x} dx\). Participants explore methods for solving this integral, including hints and techniques related to integration under the integral sign.
  • Homework-related
  • One participant requests that those who know the answer refrain from responding to encourage others to think critically.
  • Another participant humorously acknowledges the request to remain silent.
  • A hint is provided suggesting the use of integration under the integral sign as a method to approach the problem.
  • A participant claims the answer is \(\log(4/3)\) and questions how to display mathematical formulas on the message board.
  • Discussion includes a clarification that the technique mentioned is actually differentiation under the integral sign.
  • A participant elaborates on the integration technique, mentioning the use of a theorem that allows changing the order of integration.
  • Participants discuss the use of LaTeX code for displaying mathematical expressions, with one expressing frustration over the preview function not working correctly.
There is no consensus on the solution to the integral, as participants present differing views on the method and the answer. The discussion remains unresolved regarding the final result.
Participants express uncertainty about the functionality of LaTeX code on the message board, indicating limitations in verifying mathematical expressions before posting.
Ali 2
Hi,
Find the result of this integration::
[tex]\int_0^\infty \frac { e^ {-3x} - e^ {-4x} }{x} dx[/tex]
The members who know the answer previously please don't answer in order to make the other members think :cool: !
Best wishes ,
My lips are sealed! :)
Waiting .. :zzz: !
That is differentiation under the integral sign, actually.
The answer is log(4/3).
How do you do mathematical formulae on the messageboard?
Neat trick indeed, Benorin, this INTEGRATION under the integral sign. In this problem it involves the function [itex]e^{-ax}[/itex] seen as a function of 2 variables and one may use a theorem which allows changing the order of integration...
Daniel.
Jesus! That's nice. Thanks. With regards to displaying math text, use LaTex code. There is a thread in the Math and Science Tutorials forum that describes it's use or you can just click on the "quote" button to see the code. Here, I'll write the relation suggested above:
[tex]\int_a^b dx \int_{\alpha_0}^{\alpha} f(x,\alpha)d\alpha=<br /> \int_{\alpha_0}^{\alpha}d\alpha \int_a^b f(x,\alpha)dx[/tex]
Let me see,
[tex] \newcommand{\mean}[1]{{<\!\!{#1}\!\!>}}<br /> \newcommand{\braket}[2]{{<\!\!{#1|#2}\!\!>}}<br /> \newcommand{\braketop}[3]{{<\!\!{#1|\hat{#2}|#3}\!\!>}}<br /> \braket{\phi}{\psi} \equiv \int \phi^*(x) \psi(x)\,dx[/tex]This LaTeX code doesn't work when I hit 'preview post'. There's no way to check it's right.
The preview has been on the fritz for some time now, so this is 'normal'. You can edit after you post of course.
  • · Replies 27 ·
  • · Replies 19 ·
