Thread Closed
aerodynamics question
Share Thread Thread Tools
Dec9-03, 02:47 PM   #1
hello.
the question is: if i have an exact model (and i mean EXACT) of, say, a glider (you know, those whaddamacallits, white things, long, thin wings, those ones), if i have one of those, why will it not fly as well as a proper one?
(the model is a lot smaller than the real thing)
i was told that the air does not flow around a small wing as well as it does around a large one.
is that true?
if so, why so?
thanks.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Dec9-03, 03:08 PM   #2
Recognitions:
Homework Helper Homework Help
I would imagine it has something to do with there being less actual air molecules in a given scaled volume for the model, so the continuum approximation doesn't work as well. Total conjecture, though.
To elaborate on my lines of thinking with an example: Random collisions with individual air molecules will not be as evened out, because there will actually be less (statistically) in any given time. This may amplify random effects.
Dec9-03, 04:36 PM   #3
Recognitions:
Individual molecules are not the problem. The issue has to do with viscosity. The smaller the model, the more the air appears viscous. As a result, the flow is relatively more turbulent, which affects the aerodynamic properties.
Dec9-03, 07:10 PM   #4
Recognitions:
Look up something called the Reynold's number. Its gives a good rule of thumb for determining when fluid flows are similar.
Dec9-03, 10:09 PM   #5
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
With a smaller model you also get reduced lift. Along the tips of the wings, the higher pressure on the bottom of the wing 'bleeds' over to the top of the wing. With a smaller model, there is less surface area to tip area, so the wingtip vorteces have a greater effect.
Dec10-03, 12:02 PM   #6
Recognitions:
Why is that?
Dec10-03, 02:30 PM   #7
Mentor
Enigma and I are very insulted that you posted this in the General Physics forum instead of the Aerospace Engineering forum.
Dec10-03, 05:04 PM   #8
Recognitions:
[:D]
Wha? Er. Oh yeah! VERY insulted...
Dec10-03, 05:27 PM   #9
Mentor
You know... You'r right, this is an engineering discussion!
Enjoy!
Dec11-03, 08:19 PM   #10
Recognitions:
Look up "Scaling Theory" for more info. It's been many years since I studied aero-d, so I forget the details at the moment. [b(] I would need to dust off my old college textbooks. But it sounds like mathman, stingray, and enigma are on the right track. Smaller-scale models are frequently used (wind tunnels, etc.) and there is always some loss of accuracy compared to a full-scale application.
Dec11-03, 11:49 PM   #11
ken
The answer to this lies with the concept of Reynolds number.
Basically due to density and viscosity airflow forms different flows at different speeds and body sizes. Assuming that the density and viscosity are the same, you get the same flow if you double the speed and halve the body size etc. When you scale down a model, you are generally scaling down both the velocity and the size of the body
vastly reducing the reynolds number. The aristream has far less energy to keep laminar flow going long. The curvature of the body is smaller and is much more difficult for the boundary layer to stay attached to the surface. The boundary layer turbulates earlier and is of an much more significant proportion of the body. Any resulting seperation bubbles that would be insignificant on a full size aircraft can extent over a major proportion of the model wing and may in fact not reattach at all.
Reynolds number theory does not hold as good at the vaules related to models because of these scale effects.
Jan25-04, 11:33 AM   #12
is the scaled model with mass that scaled in the same propotion as the size??
Jan26-04, 11:48 AM   #13
Mentor
One thing to remember here is that mass is proportional to the cube of any dimension (and area is the square of any dimension). So if you say a plane with half the wingspan of another is half the size - its actually going to have a quarter the wing area and an eighth the volume. Even still, an rc plane is significantly lighter: I googled for a Cessna and a 152 has a wing loading of 10 lb/sq ft and a 172 is 14.5 lb/sq ft whereas an r/c Cessna has a wing loading of about 1.5 lb/sq ft.
One thing to remember is that besides being smaller, the model also flies much slower, generating much less lift per unit area of wing than the real thing. Slower + smaller = that Reynold's number thing discussed above.
Thread Closed
Thread Tools
Similar Threads for: aerodynamics question
Thread Forum Replies
Simple knife-edge (aerodynamics) question. Mechanical Engineering 8
objective question related to aerodynamics Engineering, Comp Sci, & Technology Homework 6
Aerodynamic of shipping contatners on trains Mechanical Engineering 6
Simple Aerodynamics Question Introductory Physics Homework 6
Question Concerning Aerodynamics General Engineering 0
