Recovery from hyperpolarisation and Voltage Clamp
  • Context: Medical
  • Thread starter Thread starter gamecube999
    Voltage
The discussion revolves around the recovery processes of nerve cells following hyperpolarisation, examining the roles of ion channels and the sodium/potassium pump. It also touches on the effects of voltage clamping at -120mV and the currents involved, exploring both theoretical and physiological aspects.
  • One participant questions the role of the sodium/potassium pump in recovery from hyperpolarisation, suggesting that the electrical gradient for sodium ions may be a contributing factor.
  • Another participant argues that the resting membrane potential is primarily determined by the Nernst equilibrium rather than the sodium/potassium pump, emphasizing the importance of ion permeability and concentration gradients.
  • The Nernst equation and the Goldman-Hodgkin-Katz equation are mentioned as tools for calculating membrane potentials based on ion concentrations and permeabilities.
  • It is proposed that during action potentials, the permeability to potassium increases, leading to afterhyperpolarisation, and that the sodium/potassium pump plays a minimal role in the immediate action potential dynamics.
  • One participant expresses confusion about the classification of the thread, suggesting it should be categorized under Biology instead of its current placement.
Participants express differing views on the role of the sodium/potassium pump versus the Nernst equilibrium in determining membrane potential and recovery from hyperpolarisation. The discussion remains unresolved with multiple competing perspectives presented.
There are references to specific equations and concepts that may require further clarification or context for full understanding, such as the Nernst equilibrium and the Goldman-Hodgkin-Katz equation. Additionally, the implications of ion channel dynamics during action potentials are complex and not fully resolved in the discussion.
gamecube999
What processes cause the recovery of the nerve cell after hyperpolarisation? It can't be the sodium/potassium pump because it pumps 3 sodiums out and 2 potassiums in thus lowering the cell potential. The only reason I can think of is because the inside is negative, so there is electrical gradient for sodium ions? It must be to do with the relative permeabilities but I can't find a list of permeabilities of different ions at different voltages?
Also, when you voltage clamp the membrane potential to about -120mV, there is a small inward current, which ion is responsible for that? I've done some reading and I think it could be because of the gradual depolarisation due to K+ channel inactivation, maybe there is also a 'funny' current as seen in cardiac pacemaker cells?
Biology news on Phys.org
The reason for your confusion is because of the simplistic, but erroneus way this topic is often taught in a school class. I was not even satisfied with what my standard med school physiology texts taught me about membrane equilibria, so I had done some research then. Of course, I've lost touch, but was able to refresh myself quickly with a bit of googling.
Read thru' these two links VERY carefully.
http://human.physiol.arizona.edu/SCHED/CV/Wright/14membra.htm
http://human.physiol.arizona.edu/SCHED/CV/Wright/15action.htm
The short version : the "real" reason for the resting memb pot of any cell is NOT the sodium-potassium pump (at least not directly). The real reason is something known as the Nernst equilibrium. Essentially, if you have a concentration gradient of a single ion between two sides of a semipermeable membrane that exhibits high permeability to that ion, you will get diffusion of that ion down its chemical gradient. But at the same time, that act of diffusion is accompanied by a gradually accumulating electrical gradient that opposes the movement. A point is reached where the electrical gradient will exactly counterbalance the chemical one, this point is called the Nernst equilibrium (NE). At the NE, no net ionic flux occurs and the membrane potential is stable. The NE is dependent on two things, the permeability of the membrane to the ionic species and the initiating chemical gradient. Interestingly, with a high chemical gradient and high permeability, the ionic flux required to swing a membrane from neutral to the NE potential is so slight that the original internal and external concentrations can be taken as not having altered. A lot of understanding of this whole thing hinges on that point : the actual concentrations are not really changing much at all. Rather, it is the *tendency* of movements to occur (which depends on changing permeabilities) that governs membrane potential.
The Nernst equation allows us to calculate the NE point for different ionic species. The combined equation for Na, K and Cl is the Goldman-Hodgkin-Katz equation. These two are explained in the first link I provided.
Essentially, for a resting cell, the memb pot is close to the Nernst potential for potassium. This is because the resting cell is far more permeable to K than it is to Na or Cl. The sole function of the active Na-K-ATPase is to establish the chemical gradient for K (and incidentally Na) with high K inside and low K outside. The natural leak of the K from inside to outside following this (due to high permeability to K) is responsible for causing the resting membrane potential. Just a small leak (relatively) is sufficient to establish the potential, as I explained earlier. If the pump is shut off and all else remains constant, the cell membrane will not go immediately towards neutrality because this is a stable electrochemical state (OTOH, the cell will take on water and lyse of course).
So it's now easy to explain what's going on with nerve cells. There are K channels always working in the cell that maintain the memb pot near the Nernst pot for K. A stimulus opens Na channels that moves the cell closer toward the Nernst pot for Na (which is positive). At a threshold pot, more voltage gated Na channels open up and the process is reinforced, the cell depolarises. Slower opening voltage gated K channels now start opening while the Na channels start closing, and the cell starts going back toward the K Nernst potential. At this point, the memb is even more permeable to K than in the resting state (because both the nongated and gated K channels are open) so the cell goes even further toward the K Nernst potential, resulting in the afterhypolarisation. The repolarisation toward resting memb pot is due to closing of the voltage gated K channels so that only the nongated K channels are open. The cell is now at resting memb pot.
Note the distinct lack of involvement of the active pump in the process of the AP and the aftermath - that's only involved in any residual cleanup and maintenance of osmotic pressure.
BTW, this should really be moved back into Biology, why was it moved here ?
EDIT : Hey cool, I have 666 posts. :devil: :biggrin:
Thanks a lot :D:D:D
10K
27K
