What are the three types of energy involved in an oscillating spring problem?
  • Thread starter Thread starter apchemstudent
    Oscillating Spring
The discussion centers on the energy types involved in an oscillating spring problem, specifically addressing the calculation of an object's speed at a given displacement. The object oscillates with an amplitude of 5 cm, and the angular frequency is calculated as 14 rad/s. The initial claim of a speed of 56 cm/s is disputed, with the correct calculation yielding a speed of 42 cm/s when the object is 8 cm below the initial position. The three types of energy involved are gravitational potential energy, potential energy stored in the spring, and kinetic energy.
  • Understanding of Hooke's Law and spring constants
  • Knowledge of gravitational potential energy calculations
  • Familiarity with kinetic energy formulas
  • Concept of angular frequency in oscillatory motion
  • Study the conservation of energy principles in oscillatory systems
  • Learn about Hooke's Law and its applications in spring mechanics
  • Explore the derivation and application of angular frequency in oscillations
  • Investigate the relationship between displacement and velocity in harmonic motion
Students of physics, educators teaching mechanics, and anyone interested in understanding oscillatory motion and energy transformations in spring systems.
apchemstudent
A massless spring hangs from the ceiling with a small object attached to its lower end. the object is initially held at rest in a position y such that the spring is at its rest length(not stretched). The object is then released from y and oscillates up and down, with its lowest position being 10 cm below y. What is the speed of the object when it is 8cm below the initial position?
The book says 56 cm/s, but I don't agree with it. First of all, the amplitude will be 5 cm, which, we can use to figure out the angular velocity.
K(.05) = Fg = mg
K = 196m
angular velocity = sqrt(K/m)
= 14 rad/s.
So when the object reaches the point, 8cm from y, it would've displaced only 3 cm from the "equilibrium point".
so V = angular velocity * displacement
= 14 * 3 = 42 cm/s
Am I correct here? Or is there something I'm missing? Thanks.
= 14 rad/s.
Angular velocity of what? What is rotating or circulating here?
That is why it is batter to call this quantity as angular frequency.
V = w sqrt[A^2 - x^2]
Using conservation of energy between the points y=y and y=10 cm,
and again between the points y=y and y=8 cm, should yeild the result. This is a less confusing way as far as I am concerned.
There are 3 types of energy to consider in this problem. Those are Grav. potantial energy, Potantial energy stored in the spring and the KE.
  • · Replies 17 ·
