Understanding the Formation of Contrails: A Scientific Explanation
  • Context: High School
  • Thread starter Thread starter Mk
The discussion revolves around the formation of contrails, specifically exploring why contrails are absent in certain locations, such as Guam, despite the presence of significant air traffic. Participants examine the conditions under which contrails form, including atmospheric temperature and pressure, and the role of jet exhaust in this process.
  • One participant expresses confusion about the absence of contrails in Guam, despite the presence of busy air traffic.
  • Another participant suggests that contrails form due to condensation from low pressure behind aircraft, but admits uncertainty.
  • A different viewpoint explains that contrails occur when jet exhaust becomes saturated in the air, depending on vapor pressure and temperature conditions.
  • Some participants note that Guam's proximity to the equator may result in higher atmospheric temperatures at cruising altitudes, potentially preventing contrail formation.
  • One participant mentions having observed contrails in other regions, indicating that temperature and humidity conditions vary and affect contrail visibility.
  • There is a suggestion that the moisture in combustion gases condenses to form contrails, but this is contingent on specific atmospheric conditions.
Participants do not reach a consensus on the reasons for the absence of contrails in Guam, and multiple competing views regarding the conditions necessary for contrail formation are presented.
Participants reference atmospheric conditions, including temperature and humidity, as critical factors influencing contrail formation, but do not resolve the complexities involved in these interactions.
Mk
Where do contrails come from??
I have known many answers but none seems to fit my situation.
On Guam, we have a busy commercial airport, an air force base, and a navy air base... and NO contrails. NONE. Where do contrails come from.
"Why, they come from the back of planes Mk." No, I don't want that answer.
Lemme ask my aero-engineering friends tomorrow, i'll get back to you.
I think its condensation because of low pressure building up behind the aircraft but I'm not certain.
Contrails happen when the exhaust from jetplanes become saturated in the air. This happens if the vapor pressure and temperature of the exhaust as it leaves the plane and and while it comes to equilibrium with the atmospheric vapor pressure and temperature meets the necessary conditions for saturation.
This page has a graphic:
http://cimss.ssec.wisc.edu/wxwise/class/contrail.html
Since Guam is fairly close to the equator, its atmospheric temperature at jet plane height might be great enough such that there is not enough vapor pressure to saturate in the air.
i don't know what a contrail is.
Good for you.
Errr... I mean http://cimss.ssec.wisc.edu/wxwise/class/contrail.html has a picture, its the clouds that planes leave behind.
Ahh, yes that sounds good. Guam is only 14˚ up from the equator.
It's the moisture in the combustion gases that condenses. I have seen contrails overhead since my area gets a lot of air traffic from Boston and the NE airports, and international flights into NY. However, contrails do not always form. That is a matter of air temperature as Jelfish indicated, in which case the combustion gases dissipate before condensing into the appropriate size droplets. I have been in commercial jets and seen other commercial jets flying underneath or overhead in the opposite direction (which is pretty amazing to see), and there were no contrails. That's more the case in the summer than during the cooler fall, winter and spring periods.
Typcial altitudes for big commerical jet aircraft are about 8000-12300 m (26000 - 40000 ft) over land, with slightly higher altitudes over the ocean (10000-14000 m) for transcontinental flights. Short range flights tend to be at the lower altitudes to minimize congestion of the airspace.
  • · Replies 16 ·
  • · Replies 40 ·
  • · Replies 18 ·
  • · Replies 22 ·
