Electromagnetic waves in a vacuum
The discussion revolves around electromagnetic waves in a vacuum, specifically focusing on their transverse nature and the implications of boundary conditions when these waves interact with different media. Participants explore the relationship between electric and magnetic fields, Maxwell's equations, and the behavior of waves at boundaries.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss how to demonstrate that electromagnetic waves are transverse and question the implications of a vacuum on this property. There are inquiries about deriving the wave equation from Maxwell's equations and the significance of curl operations in establishing perpendicularity between electric and magnetic fields.
The discussion is active, with participants sharing insights about boundary conditions and referencing Fresnel's equations. Some have provided specific equations related to reflected and transmitted waves, while others are seeking clarification on the effects of conduction electrons on electromagnetic waves and how they modify Maxwell's equations.
Participants note the importance of understanding the assumptions behind the behavior of waves in different media, including the presence of free charges and currents, and how these factors influence the application of Maxwell's equations.
scariari
show that electromagnetic waves in a vacuum are transversal waves.
transversal waves mean that the electric and magnetic wave fields are always perpendicular to each other and to the direction of the wave propagation... but how does this link to a vacuum? and how can you show that a field is perpendicular?
consider an electromagnetic plane wave and assume that it hits a boundary of a medium under a certain angle. assume that the dielectric constant, and magnetic permeability of the medium are given.
what are the boundary conditions on the electric and magentic fields at the boundary of the medium?
are there solutions for the plane waves that come in perpendicular to the boundary? (find them)
a plane wave is a wave traveling in the x-direction and has no y- or z- dependence. hitting a medium under a certain angle= a case of oblique incidence?
if the symbols were easier to type, i would write my answer, but to make sure, there are 4 boundary conditions for the case of it being parallel, in which #1 and #4 reduce to one common one and the third boundary condition also reduces.
for the case of it being perpendicular, it should have some connection with being parallel, but what? i assume that since the electric and magnetic fields are already perpendicular to one another, that there will only be two boundary conditions because not both the electric and the magnetic field can be perpendicular to this medium...
suppose that the medium would also contain a constant density of free electrons that respond to electric fields according to Ohm's law, describe the effect of the conduction electrons on the wave.
putting a free charge on a conductor makes it flow out to the edges. magnetic fields in a conductor lag behind the electric field, thus energy is not equally shared between the electric and magnetic fields. HELP!
Vacuum means 'no charges and no currents'. You got to transform Maxwell's equations for this case into a wave equation. You will find the answer in a standard electrodynamics book, e.g. Jackson.
Maybe. This is all standard work (deriving things directly from Maxwell's equations) than can be found in the literature (or probably on the web...). Search for 'Fresnel's formulae'.
The reference to Ohm's law means that the body is not a perfect conductor in which charges can move with light speed. Instead, the current density will be proportional to the E-field strength. In what you say, you seem to refer to an induced current but that's not the case here.
sorry about the first post, i didnt include the whole problem: part a asks to derive the wave equation from Maxwell's equations. I did that no problem, but i guess question is
(from David J. Griffiths' "Introduction to Electrodynamics, chapter 8)
how does the fact that
curl.E =0 and
curl.B=0
show that electromagnetic waves are transverse?
(excuse the following confusing typing)
how does
curlxE=-dB/dt (faraday) implies
-k(E0)x=w(B0)y
-k(e0)y=w(b0)x or
B0=k/w(ixE0)
show that E and B are mutually perpendicular?
about the second part, the boundary conditions at the boundary of the medium:
FIRSTLY, in the previous reply i used "CURL" instead of "del", my appologies...
about the second part of the original question, the boundary conditions at the boundary of the medium: i found 4 b.c's; for reflected perpendicular, transmitted perpendicular, reflected parallel, and transmitted parallel cases.
these are fresnel's equations.
this means that there are solutions for plane waves that come in perpendicular to the boundary, correct?
for oblique
reflected:
E0R=((n2 cos theta- n1 cos theta)/(n1 cos theta + n2 cos theta))E0I
transmitted:
E0T=((2n1 cos theta) /(n1 cos theta + n2 cos theta))E0I
for perpendicular
reflected:
E0R=((n1 cos theta- n2 cos theta)/(n1 cos theta + n2 cos theta))E0I
transmitted:
EOT=((2n1 cos theta) /(n1 cos theta + n2 cos theta))E0I
about the last part:
the effect of the conduction electrons on the wave changes the maxwell equations , right?
del. E=(1/e)pf
del. B=0
delXE=-dB/dt
delXB=(mu)(sigma)E+(mu)(epsilon)dE/dt
can an Ohmic conductor be categorized as a "poor" conductor or just a normal conductor?
  • · Replies 17 ·
  • · Replies 38 ·
