Diff Eq problem, finding the small value and large value of k?
  • Thread starter Thread starter mr_coffee
    Diff eq Value
The problem involves finding two specific values of k for which the function y(x) = e^(kx) satisfies a given second-order linear differential equation, y'' - 16 y' + 60 y = 0. The context is within the subject area of differential equations.
  • Exploratory, Mathematical reasoning
  • The original poster attempts to derive the necessary conditions by substituting the function and its derivatives into the differential equation. They express uncertainty about the systematic approach to finding k, having tried guessing values without success.
Some participants have noted the transformation of the equation into a quadratic form, k^2 - 16k + 60 = 0, suggesting that there is a systematic method to solve for k. The quadratic formula is mentioned as a possible solution method, and there is acknowledgment of the algebraic steps involved.
Participants are discussing the algebraic manipulation required to solve the quadratic equation, with some expressing familiarity with the quadratic formula as a systematic approach. There is an indication that the original poster is seeking clarity on the process rather than a direct answer.
mr_coffee
Hello everyone I'm lost on how they want me to approach this:
Find the two values of k for which
y(x) = e^{kx}
is a solution of the differential equation
smaller value =?
larger value = ?
I did the following:
y(x) = e^(kx);
y' = ke^(kx);
y'' = k^2e^(kx);
(k^2e^(kx)) - 16(ke^(kx)) + 60(e^(kx)) = 0;
is there a sysematic way to solve this problem rather then just trying to randomly guess numbers? i tried the randomly guessing k values and it isn't working out :bugeye:
Any help would be great!
thanks!
so you have:
or slightly rewriten
(k^2 - 16k + 60) e^(kx) = 0
then since e^(kx) is never 0
k^2 - 16k + 60 = 0
I believe there might be some sort of systematic
way to figure out what k is. i seem to remember
some sort of an algebraic formula...
Thanks again qbert! worked out great! good old quadratic formula!
low = 6, high = 10.
:smile: good one. Yeah, just solve for k. Once you take the derivatives and plug them in. the rest is just algebra.
