How Do Tractor Forces Combine When Pulling at an Angle?
  • Thread starter Thread starter balletprincess34
    Force Physics
The discussion revolves around the forces exerted by two tractors pulling at an angle of 36 degrees relative to each other, with each tractor applying a force of 8000N on a 1750kg object. Participants are exploring how to calculate the total force exerted by the tractors on the object.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the use of the law of cosines and vector addition to determine the resultant force. There are questions about the interpretation of the angle and how it affects the calculation of force components.
Some participants have provided guidance on interpreting the problem and calculating the vertical and horizontal components of the forces. There is an ongoing exploration of different methods to arrive at the total force, with no explicit consensus reached on the final answer.
Participants note assumptions about the alignment of the tractors and the effects of gravity on the object, indicating that these factors may influence the final calculations. There is also mention of potential guessing in understanding the question's requirements.
balletprincess34
two tractors pull against a 1750kg. if the angle of the tractors' chains in relation to each other is 36.0 degrees and each tractor pulls with a force of 8000N what is the total force exerted by the tractors
is the answer 15200N?
yes, approximately.
thank u...i just wanted to double check :)
I am curious, how did you arrive at this answer?
process of elimination, law of cosines, formula for calculating force weight...etc etc...
there was a fair amount of guessing about the question, but I think that it was asking what the resulting force on the object is. Then, if the tractors are pulling at a 36 degree angle from each other, they are pulling at a 18 degree angle from the horizontal (_assuming_ that they are aligned around the horizontal) From then, I just added the vectors. At least, I think that's what the question is asking.
Hmmmm, not sure how you derived 15,200N using those methods. Perhaps you can explain? :confused:
In my interpretation of the question, I sense, if the tractor chains are pulling at 36 deg angle from each other, then they are each 18 deg from the vertical, meaning they are 72 deg from the horizontal.
Since you are only determining the total force exerted by the tractors (and ignoring the force exerted by gravity on the object with mass 1750kg), you can calculate the horizontal and vertical force components for each chain. The horizontal forces are equal and opposite in direction, so therefore cancel. That leaves the vertical component for each chain.
Just calculate one of them (Fy) and multiply by 2.
(Assuming that both tractors are taller than the mass their chains are attached to) Fy(total) = 2*(8000sin72) = 15217N in upward direction.
If you do take into account the vertical force of gravity on the 1750kg object, then what would be the total resultant force of the system? and in what direction?
11K
9K
  • · Replies 23 ·
14K
