What is the relative velocity of the airplane to the surface
The discussion revolves around calculating the relative velocity of an airplane flying east at 800 km/h while encountering a wind from the southwest at 80 km/h. Participants are attempting to determine both the speed and angle of the airplane relative to the ground.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss breaking down the wind's velocity into horizontal and vertical components and how to combine these with the airplane's velocity. There are questions about the accuracy of the drawn vectors and the resulting calculations. Some participants express confusion over the angle and the use of trigonometric functions.
Several participants have provided guidance on vector decomposition and the use of the Pythagorean theorem. There is an ongoing exploration of how to derive the angle from the components, with some participants confirming their calculations while others seek clarification on their methods.
Participants note discrepancies in their calculations and the importance of correctly interpreting the components of the wind and airplane velocities. There is an acknowledgment of the challenge in visualizing the problem due to the orientation of the vectors involved.
balletprincess34
ok i have tried to draw this problem several times and i get different answers every time...my answers range from 804-880km/h and i can't get the degree down either...please help...
an airplane pilot tries to fly directly east of the velocity of 800.0km/h if a wind comes from the southwest at 80.0km/h what is the relative velocity of the airplane to the surface of the earth...how do u do this mathematically? please help!
Break the vectors into components and add them
Welcome balletprincess34 to the Physics Forums ! :smile:
You have an interesting question.. You have correctly completed the first step in asking a question on HW forums, describing your problem.. The next step, before we can help you, is to explain what you have done so far and where you are getting stuck.. (Besides the range of answers you found, how did you get there?)
don't worry, we have plenty of helpful & knowlegable folks here who will be happy to steer you in a successful direction. Andrew has already given you some useful information. We can always elaborate on that if you don't understand..
Be sure to read this https://www.physicsforums.com/showthread.php?t=94379 at the top of this subpage to useful advice in using this forum.
well for the most part i just drew the vectors...however depending on my scale...the answers varied like i would get one measurement but the incorrect angle value...how can u just solve this problem mathematically...i know that u have to break the 80.0km/hr in its vertical and horizontal components and i got 56.569 for both components...but what do i do now?
56.569 is your horizontal component for the wind and
56.679 is your vertical component for the wind.
What are your horizontal and vertical components for the airplane?
well if the airplane is flying directly east wouldn't that mean that the entire component is horizontal and the vertical component is equal to zero?
Yes. So the airplane's horizontal component is 800 and its vertical component is 0. Now you can add them to the wind's components.
ok so i got 858km/hr...now how can i solve for the angle?
You weren't asked to solve for the angle. But if you want to know it, use Trig. You are asked for the airplane's speed relative to the ground. Construct a triangle with the horizontal component and vertical component as 2 legs. Do you know how to find the hypotenuse of this triangle?
Also, 858 km/hr is the horizontal component. What about the vertical component?
Actually, how did you get 858? It's close but not quite right.
wait i just used pythagorean thm to solve for the 858km/hr and thanks fer the angle help...i get the problem now..i just always to forget to add the components first...thanx again
Sorry, you were a step ahead of me. 858 is correct. sqrt(856.6^2+56.6^2).
To get the angle, draw a triangle. You know all 3 sides, so you can use SIN, COS or TAN to get the angle. And since they ask for velocity, not speed, you should include this angle in your answer.
all right ok so i got 858km/hr at 3.8 degrees N of E...is that what u got? i hope so and thank u sooo much fer all your help! :)
yes. That's what I got. Making a triangle, the vertical component of 56.6 is opposite the angle. The horizontal component of 856.6 is adjacent the angle. TAN-1(56.6/856.6)=3.8 degrees. Since the wind comes from the southwest, it pushes the eastbound aircraft north of east. Aren't these easy!
Thanks for jumping in Tony, I didn't get back to this thread till just now. BTW how did you get different values for F(wind_horiz) and F(wind_vert)??
[I get the same value for sin (45 deg) and cos (45 deg)]
The most confusing part of this question is interpreting horizontal and vertical velocities of wind and the airplane, as both being parallel to the Earth's surface.
What we normally think of as vertical in space is actually perpendicular to both vertical and horizontal velocity axes in this question.
Once we realize this, the rest of the problem becomes easy.
Typo :rolleyes:
  • · Replies 17 ·
  • · Replies 18 ·
  • · Replies 21 ·
  • · Replies 20 ·
  • · Replies 88 ·
