Maximizing Projectile Range: Motorcycle Daredevil Bus Jump
The problem involves a motorcycle daredevil attempting to maximize the number of buses jumped over, given specific parameters such as the angle of takeoff, speed, and width of the buses. The subject area includes projectile motion and kinematics.
  • The original poster attempts to calculate the time of flight using the vertical component of the velocity and questions whether their approach is correct. Another participant raises a related question about the time it takes for a projectile to return to its starting height. There is also a mention of using kinematic equations to analyze the projectile's motion.
Participants are exploring different aspects of the projectile motion problem, with some providing guidance on using kinematic equations. The original poster has made progress in their calculations, but there is no explicit consensus on the final outcome or method.
The discussion includes assumptions about the projectile's path and the effects of gravity, with specific values for initial velocities and acceleration due to gravity being referenced.
gsr_4life
A motorcycle daredevil is attempting to jump across as many buses as possible. The takeoff ramp makes an angle of 18.0 degrees above the horizontal, and the landing ramp is identical to the takeoff ramp. The buses are parked side by side, and each bus is 2.74m wide. The cyclist leaves the ramp with a speed of 33.5m/s. What is the max number of buses the cyclist can jump?
I know that this is a question of range involving a vector x. I know that Vo =33.5m/s, Vox= 31.86m/s and Voy= 10.35m/s using sin and cos of 18degrees. What I am having trouble with is finding time "t" so I can use the range equation. I am not even sure if I am going about this right. Any help would be great, thanks.
If you shoot a ball up into the air with the initial vertical velocity of Voy= 10.35m/s, how long before it comes back down to its starting height? (And what will its downward Vy be then?)
Realize your projectile takes a parabolic path, therefore [tex]d = v_ot + 1/2at^2[/tex], where d = 0.
Got it!
I set up a table of values for displacement of y=0, a=-9.8, Vo=10.35 and used the equation y=volt+1/2a * (t squared) and plugged t into the equation Voxt=R and divided it by 2.74 = 24 buses
13K
