Sonic Boom: What Physics Property Prevents Air Particles?
  • Thread starter Thread starter goozooloo
The discussion revolves around the physics of sonic booms and the properties of air that prevent air particles from exceeding the speed of sound. Participants explore concepts related to fluid dynamics, shock waves, and the behavior of air molecules in different conditions, including altitude effects and temperature variations.
  • Some participants suggest that air can exceed the speed of sound under certain conditions, such as in converging-diverging nozzles used in jet engines.
  • One participant describes the phenomenon of shock waves and how they relate to the speed of an aircraft, explaining that the shock wave is a sound wave that cannot outrun the aircraft.
  • Another participant raises the idea that the translational speed of air molecules and their mean free path may contribute to the inability of air to exceed the speed of sound.
  • There is a discussion about the relationship between air density, temperature, and the speed of sound, with conflicting views on how these factors interact at different altitudes.
  • Some participants express confusion about the effects of altitude on the speed of sound, with one asserting that the speed increases with decreasing density, while another corrects this by stating that it actually decreases due to lower temperature.
  • A later reply discusses the kinetic theory of gases and how it applies at high altitudes, suggesting that conventional gas dynamics may not be sufficient to explain the behavior of air molecules in those conditions.
Participants express multiple competing views regarding the factors that influence the speed of sound and the behavior of air particles. The discussion remains unresolved, particularly concerning the effects of altitude on the speed of sound and the interpretation of temperature in relation to molecular motion.
Limitations include varying assumptions about the behavior of air at different altitudes and the definitions of temperature and speed of sound in relation to molecular dynamics. Some participants reference previous threads and concepts without fully resolving the underlying complexities.
goozooloo
Could some one tell me what is it called in physics (name of property etc. ) that does not allow air particles to move past the speed of sound?
Air can travel faster than the local speed of sound given the proper conditions. The first example I can think of is the exhaust gases out of the space shuttle and jet engines. This is accomplished by using converging-diverging nozzles.
You may be thinking of a choked flow condition where a fluid speed is limited to the maximum of speed of sound. It is however not an absolute and can be overcome with differernt flow geometry.
Perhaps you can restate your question?
Well basically, when an aircraft moves faster than the speed of sound it tries to push the air along that same speed right? but the reason for the sonic boom is that the air cannot excede that limit. what causes this to occur?
thanks for ur reply
I think the basic idea is the translational speed of the air molecules (about 400 m/s and the mean free path on a molecular level. were you more thinking along these lines? Basically the air molecules are not "communicating" fast enough.
thanks for ur reply
That isn't really what is happening. The shock wave is a plain, ordinary sound wave that due to the speed of the aircraft, can't outrun the aircraft. Sub-sonic aircraft push pressure waves out in a circular (from the ground) pattern. Pile these circles up and you get a cone, with all the waves concentrated on the "surface" of the cone.
See previous thread on the subject: https://www.physicsforums.com/showthread.php?t=101281 ...and my post:
Me said:
The best explanation I've seen is using water drops: if you drip water into a pool, concentric circles form as the wave expands from where the drop hit. If you do a steady drip, drip, drip, these waves will continually move away from the impact point. If you start to move the impact point slowly, the waves will still be able to move forward away from the impact point and you'll end up with circles that are not concentric, but still moving away from the impact point in all directions. If you move faster than the waves can move, all the circles you make will be behind the impact point, and their diameters will be larger the further from the impact point, forming a cone. HERE is a picture of the phenomena using a plane, but the circles are there...
Remember also that all motion is relative, and except in the passing of the wave and friction from the plane, the air molecules don't actually need to be moving much relative to the ground. In fact, if air molecules are being pushed at high speed, that's an indicator of high drag. Still, when the Space Shuttle blasts into the atmosphere at 10,000 mph, air molecules are going to bounce off that blunt nose at 10,000 mph. In fact, that's what keeps it cool: the bluntness pushes air out in front of it like a snow-plow, keeping the shock wave (and it's enormous pressure induced temperature rise) away from the space shuttle).
Had never thought about the cooling effect the bow wave had on things like the shuttle, thanks Russ.
Thanks for the info
however you sed that the air molecule bouncing off the nose of the space shuttle is still traveling at 10,000 km/h, if so then why doesn't the shockwave travel at that speed since its carried by those molecules. I think the effect here is friction, that's why the speed of sound becomes higher and higher as air density gets lower with gains in altitude. Just what i think, if you would please correct me if I am wrong.
Thanks
goozooloo said:
thats why the speed of sound becomes higher and higher as air density gets lower with gains in altitude. Just what i think, if you would please correct me if I am wrong.
Thanks
Actually this is wrong. By gaining altitude the speed of sound decreases because of decrease in temperature a = (T*gamma*R)^1/2. I don't see how the soundspeed would go up with decrease in density where did you read that??
Actually temperature arises from upper stratosphere layers on.
Very true Claussius,
Only I don't think goozooloo had this in mind
by that time the air density is so low that conventional gas dynamics can no longer be used and one has to refer to kinetic theory and individual molucules hitting the surface of an object.
Jaap
Isnt it- its "hot" in the upper atmosphere because the air molecules are moving so fast, however, they are so far and few between, it feels very cold. Yes? No? Maybe so?
Sorry, missed this before...
Thanks
Yes, the molecules would be moving fast and transfer all that energy (the speed of sound depends on temperature), but then those molecules would need to do a big billiards game to send all that energy through the atmosphere. The atmosphere is big, so the energy quickly gets absorbed into a standard shockwave based on the prevaling temperature.
No: temperature is average kinetic energy of the particles, not kinetic energy per unit volume - so the density doesn't matter.
THANKS, i think i got the basic idea now :smile:
  • · Replies 53 ·
9K
  • · Replies 41 ·
18K
  • · Replies 20 ·
9K
