Does the series f_n(x)= x^n/1 + x^n converge on the interval [0,1]?
  • Context: Undergrad
  • Thread starter Thread starter Pearce_09
    Analysis Convergence
The discussion centers around the convergence of the series defined by f_n(x) = x^n / (1 + x^n) on the interval [0, 1]. Participants explore various aspects of convergence, including specific values of x and the behavior of the series as n approaches infinity.
  • Some participants question whether the series converges at x = 1, noting that f_n(1) is constant and does not decrease as n increases.
  • Others clarify that the term "series" may be misused and suggest that the discussion might be more about the convergence of a sequence rather than an infinite sum.
  • It is noted that for x = 0, the sequence converges to 0, while for x = 1, it converges to 1, raising questions about the convergence of the infinite series.
  • Some participants propose using the integral test to analyze convergence for x < 1, suggesting that the series converges in this case.
  • Another participant suggests applying the ratio test and comparison test, concluding that the series converges for x in [0, 1) and diverges for x ≥ 1.
  • There is mention of the alternating series test for negative values of x, indicating that the series converges for x in (-1, 0).
  • One participant summarizes that for |x| < 1, the series converges to 0, while for |x| > 1, it converges to 1.
Participants express differing views on the convergence of the series at specific points, particularly at x = 1, and whether the term "series" is appropriately used. There is no consensus on the overall convergence behavior across the entire interval [0, 1].
Some discussions involve assumptions about the definitions of sequences versus series, and the implications of convergence based on the behavior of terms as n increases. The application of various convergence tests introduces additional complexity that remains unresolved.
Readers interested in series convergence, mathematical analysis, and the behavior of functions on specific intervals may find this discussion relevant.
Pearce_09
[tex]f_n(x)= x^n/1 + x^n[/tex]
does this series converge on the interval [0,1]
Say if x = 1 then the series is < some epslon , where epslon is > 0
but if x = 1 then the value for [tex]f_n(x)[/tex] is constant for all n
but does this still mean the series converges.. even tho the series doesn't get smaller for large values of n...
if not then it doesn't converge?
read what you posted one more time... your answer is in there somewhere :wink:
I assume you mean [itex]f_n(x)= \frac{x^n}{1+ x^n}[/itex] since otherwise (i.e. if you mean [itex]f_n(x)= 2x^n[/itex]) I see no reason for the "1". Also It's not clear whether you mean a "sequence" rather than "series" (which is an infinite sum) since you say "even tho the series doesn't get smaller for large values of n". A sequence doesn't have to "get smaller", just get closer to (or be) a number (an infinites series does not converge it the sequence does not go to 0). fn(0)= 0 for all n and the "constant" sequence 0 certainly converges to 0 (and the infinite sum is also 0!). fn(1)= 1 for all n so the sequence "converges" to 1 but that means that the infinite series [itex]\sum f_n(1)[/itex] does not converge. For x any number between 0 and 1, we can divide both numerator and denominator by xn to get [itex]\frac{1}{1+\frac{1}{x^n}}[/itex]. That sequence also converges to 0 so the series may converge. Since these are all positive values, we can apply the integral test: The series [itex]\sum \frac{x^n}{1+ x^n}[/itex] will converge if and only if the infinite integral [itex]\int_1^\infty \frac{x^y}{1+ x^y} dy[/itex] converges (for 0< x< 1). To integrate that, let u= 1+ xy. Then du= ln(x) xy so
[tex]\int_1^\infty \frac{x^y}{1+ x^y} dy= \frac{1}{ln x}\int_{1+x}^1\frac{du}{u}= -\frac{ln(1+x)}{ln(x)}[/tex]
Okay, that exists (and is positive since x< 1), and so the series converges for all x< 1.
The sequence of functions converges to the discontinuous (at 0) function f(x)= 0 for 0<= x< 1, f(1)= 1.
The series converges on [0, 1).
It's much easier to apply the ratio or comparison test.
Let [itex]s_n = \sum_{n=0}^\infty f_n(x)[/itex]
Obviously sn diverges for x>=1 since fn converges to 1 for x=1 and diverges for x>1. Thus we are only concerned with abs(x)<1. Note that each term fn in sn is positive for all x>0 and that the terms alternate in sign for x<0.
Ratio test: Each term in sn is positive for all x>0.
sn is a convergent series if [itex]f_{n+1}(x)/f_n(x) < 1[/itex] for all sufficiently large f. The ratio converges to x for x<1, so sn is convergent for [itex]x\in [0,1)[/itex].
Comparison test: The series [itex]\sum_{n=0}^\infty x^n[/itex] converges for all x in (-1,1). For all x>0, each term [itex]f_n(x) = \frac{x^n}{1+x^n}[/itex] is smaller than [itex]f_n(x) = x^n[/itex]. Thus sn is convergent for [itex]x\in [0,1)[/itex].
Alternating series test: The sequence [itex]\frac{\lvert x^n\rvert}{1+x^n}[/itex] is monotonically deceasing for [itex]x\in(-1,0)[/itex] and some sufficiently large n. Thus the alternating series \sum_{n=0}^\infty f_n(x), x\in(-1,0)[/itex] is convergent.
It looks easy...
If [tex]|x| < 1[/tex] it obviously converges to 0.
If [tex]x = 1[/tex] it is always [tex]1/2[/tex].
If [tex]x = -1[/tex] it doesn't converge, considering [tex]n[/tex] can take odd values.
If [tex]|x| > 1,[/tex] [tex]f_n(x)=x^n/(1+x^n) = 1/(1/x^n+1)[/tex], so it converges to 1.
