Set up an infinite row of dominos and knock over the first one
  • Context: High School
  • Thread starter Thread starter godspeed
    Infinite Row Set
The discussion revolves around the behavior of an infinite row of dominos when the first one is knocked over. Participants explore concepts related to energy transfer, gravitational potential energy, and the effects of energy loss due to sound and heat. The conversation touches on theoretical implications of perpetual motion and the mechanics of domino cascades.
  • Some participants propose that the primary energy source for a domino cascade is gravitational potential energy, which is converted into kinetic energy as each domino falls.
  • Others argue that the cascade will accelerate due to the angular action of the falling dominoes, which increases the speed of subsequent dominos.
  • A participant suggests that the energy in the next falling domino comes not only from the domino that hits it but also from its own potential energy, implying that this could sustain the cascade indefinitely.
  • Concerns are raised about whether the line of falling dominos could accelerate to the speed of light, questioning the limits of acceleration in this context.
  • Another participant counters that the acceleration will not be continuous and that energy losses from sound, heat, and mechanical vibrations will decrease the efficiency of energy transfer, leading to a constant speed rather than perpetual motion.
  • It is noted that the gravitational potential energy was initially stored in the system when the dominos were set up, which is crucial for the cascade to begin.
Participants express differing views on whether the domino cascade can continue indefinitely or if energy losses will eventually halt the process. The discussion remains unresolved, with multiple competing perspectives on the mechanics involved.
Participants have not specified certain parameters, such as the geometry of the dominos or the strength of the gravitational field, which may influence the outcomes discussed. Additionally, the assumptions regarding energy loss and efficiency are not fully explored.
godspeed
i'm new to this forum and from first glance it seems like a great place to learn. i have a pretty simple question regarding dominos. if one was to set up an infinite row of dominos and knock over the first one, will the dominos fall for eternity, or will the energy decrease over time from loss due to sound and heat until one domino simply was not hit with enough force to knock the next domino over? some of my friends think energy will be lost and because of the conservation of energy that they will at some point stop, and others think that once you knock over one domino gravity will always accelerate the next enough to knock the next domino over so that it will fall indefinitely. what will really happen and why? thanks.
The primary energy source for a domino cascade is gravitational potential energy (GPE); every time a domino falls, its GPE is converted into kinetic energy, thus fueling the cascade.
In a domino cascade, not only will the progression occur, it will actually accelerate! The acceleration effect is cause by the fact that the prior domino, now tilted with force, hits the next domino below the top. This angular action increases the speed of the next dominos top relative to the previous one. And so on.
The energy in the next falling domino doesn't just come from the energy transferred from the domino that hits it. If that were the case, then the cascade would eventually stop. But each standing domino also contains it's own potential energy, which was given to it by it's being lifted into an unstable equilibrium by whoever set them up. This will most probably be enough to keep the cascade going for eternity.
The kinetic energy of the striking domino only has to have enough force to overcome the threshold energy that trips the domino out of it's vertical unstable equilibrium. How much energy comes from that domino falling over is a functioon of the geometry of the domino and the strength of the gravitational field, which you haven't specified.
are you sure it would get faster and faster? cos with enough time would not the line be falling at the speed of light? (asuming they don't break from each inpact of hitting another one)
No, it would not accelerate continuously. The acceleration to which Pallidin referred also increases the impact between one domino and the next. Sound waves and heat as well as mechanical vibration of the individual dominos will increase, thus decreasing the efficiency of energy transfer from each collission. This loss of efficiency will fairly quickly reach a state of equalibrium with the energy being fed into the system, resulting in a constant speed.
BTW, in case you're wondering where the energy originally entered the system to make this appearance of perpetual motion, the gravitational potential energy was stored in the system when the dominos were first being set up.
  • · Replies 46 ·
  • · Replies 16 ·
  • · Replies 69 ·
18K
