Calculating Time of Force Application in Non-Uniform Motion
  • Thread starter Thread starter neoking77
    Impulse Momentum
The problem involves calculating the time duration of a force application on a mass undergoing non-uniform motion, specifically transitioning from an initial velocity in one direction to a final velocity in another direction. The subject area includes dynamics and vector analysis.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the challenge of dealing with initial and final velocities in different directions and question how to appropriately calculate time given the vector nature of the velocities. Some suggest breaking down the velocities into components, while others propose using integration to derive the equations of motion.
The discussion is ongoing, with participants exploring various mathematical approaches to the problem. Suggestions include using vector components and integrating the force equation, indicating a productive exploration of the topic without reaching a consensus on a single method.
Participants note the complexity introduced by the different directions of the initial and final velocities, as well as the need to consider the force's components in their calculations. There is an acknowledgment of the constraints posed by the problem's setup and the nature of the forces involved.
neoking77
A 230N force causes a 4.0kg to accelerate from 5.0m/s North to 3.0m/s east. for how much time does hte force act?
t = m(vf-vi) / F
i got this but the trouble is vf and vi are in different directions...and since t is not a vector i can't break it down to components. what should i do?
Maybe you can do it by this way.
let [tex]\vec{v_i} =(0,5)[/tex] [tex]\vec{v_f}=(3,0)[/tex]
so [tex]\Delta \vec{v} =(3,-5)[/tex]
You can integrate
[tex]\frac{d\vec{v}}{dt} = \frac{\vec{F}}{m}[/tex]
Your solution will be two equations (one for each component of velocity). You know the initial and final velocity vectors. Your unknowns are the two components of [itex]\vec F[/itex] and t but you also know
[tex]F^2 = F_x^2 + F_y^2[/tex]
where F = 230 N. You should be able to handle the details.
using
[tex]F_x\Delta t\ =\ m\Delta v_x\ =\ a[/tex]
[tex]F_y\Delta t\ =\ m\Delta v_y\ =\ b[/tex]
and then
[tex]a^2\ +\ b^2\ =\ \Delta t^2 \mid F\mid^2[/tex]
  • · Replies 17 ·
  • · Replies 24 ·
