Calculating Current in a Series Circuit with Inductance and Resistance
  • Thread starter Thread starter alamin
    Electricity
The discussion focuses on calculating the current in a series circuit that includes a coil with an inductance of 20 H and a resistance of 10 Ohms connected to a 12 V battery. The rate of change of current can be determined using the formula I(t) = (V/R)(1 - e^(-Rt/L)), where V is the emf, R is the resistance, and L is the inductance. The final current is calculated as I_final = V/R, resulting in a steady-state current of 1.2 A. After 3.0 seconds, the current can be computed using the same formula, yielding a specific value based on the time constant of the circuit.
  • Understanding of Ohm's Law
  • Familiarity with inductance and resistance in electrical circuits
  • Knowledge of exponential functions and their applications in circuit analysis
  • Ability to apply Kirchhoff's laws in series circuits
  • Learn about the time constant in RL circuits
  • Study the application of Kirchhoff's voltage law in series circuits
  • Explore the behavior of transient currents in inductive circuits
  • Investigate the effects of varying resistance and inductance on circuit performance
Electrical engineering students, circuit designers, and anyone interested in understanding the dynamics of current flow in inductive circuits.
alamin
A Coil with an inductance of 20 H and a resistance of 10 Ohms is connected in series with a battery of emf 12 V and a switch. Calculate the
a. rate of change current and the final current.
b. current after 3.0 seconds.
You should post in the Homework section next time, and you need to provide what you have done so far with the problem, and what equations/formulas you can plug-in/apply.
  • · Replies 42 ·
  • · Replies 21 ·
