Moment of inertia about center of solid sphere
The discussion revolves around calculating the moment of inertia for a spherical shell and its relationship to the moment of inertia of a solid sphere. The original poster presents a problem that involves integrating to find the moment of inertia and expresses confusion regarding their calculations and the specific formulas applicable to different geometries.
  • The original poster attempts to derive the moment of inertia using integration and questions the validity of their result. Some participants suggest alternative coordinate systems for integration and clarify the distinction between the moment of inertia for a solid sphere and a spherical shell.
The discussion is ongoing, with participants providing clarifications about the formulas for the moment of inertia of different shapes. There is an exploration of the implications of the problem's requirements, and some guidance has been offered regarding the correct interpretation of the moment of inertia in relation to the axis of rotation.
Participants note that the original poster's confusion may stem from the problem's structure, which requires finding the moment of inertia of a solid sphere before addressing the spherical shell. There is also mention of the specific formulas for different geometries and axes of rotation.
darkar
Here's the question:
Show that the moment of inertia of a spherical shell of radius R and mass m is 2mR²/3. This can be done by direct integration or, more easily, by finding the increase in the moment of inertia of a solid sphere when its radius changes. To do this, first show that the moment of inertia of a solid sphere of density ρ is I=(8/15)πρR⁵. Then compute the change dI in I for a change dR, and use the fact that the mass of this shell is dm = 4πR²ρdR.
What I did is using I = ∫r²dm=∫4πr⁴ρdr=4πρR⁵/5=3MR²/5.
what is wrong with my equation? And please note that I am not asked to ask moment of inertia about the diameter.
Thanks ~
Just glancing at your equation it looks like you are essentially integrating in spherical coordinates. Usually cylindrical coordinates is easier and more direct.
Although you are not asked about the moment of inertia about the diameter the formula given in the problem is for the moment of inertia about the diameter. It looks to me like you are trying to take the moment of inertia around the center, which is not possible since you can't rotate about the center.
-Dale
Well, the moment of inertia about the diameter is not 2MR²/3 but is 2MR²/5 instead. So i would say it is not about the diameter.
Read carefully. 2/5 is for a solid sphere and 2/3 is for a spherical shell. Both rotated about the diameter.
-Dale
Oh rite! Thanks for pointing the wrong. I think the question confused because of the second part which asked me to find the solid sphere first.
Thanks Dale ~
  • · Replies 40 ·
