vlamir
- 149
At the time, it is cramped in the microcosmos of forum Theory Development; therefore I scrambled out to take the fresh air among the admirers of cosmic space.
I have the important occasion to talk about gravitation and inertia.
I managed to find the formula for gravitational electron mass in units of angular acceleration
[tex]M_e=\frac{g_c}{\pi D_s}=\frac{2c^2}{\pi D^2_s}=1.463681837\times 10^{36}\ \ \frac{1}{s^2}[/tex]
Where
[tex]D_s=197.714\times 10^{-12}\ \ m[/tex] – the static diameter of hydrogen radial polytron (or approximate diameter of electron);
[tex]g_c=\frac{2c^2}{D_s}[/tex] – the centripetal acceleration of ergoline in polytron (or the curvature of speed of light);
This formula expresses the current state of real world.
The Earth is rotate around own axis and around of the Sun.
The solar system is rotate around of center of our Galaxy.
Our Galaxy is rotate around of center of some other Supergalaxy, etc.
Some of these systems can be rotating with accelerating; others can be rotating with slowing. The total of rotary accelerations influences the value of gravitation and mass in each point of space and time.
Besides, all these systems vibrate – from cosmic objects until atoms and below.
Atoms consist of vibrant energy rings - from polytrons.
The vibration of polytrons creates in space the electrical and magnetic forces, which are indissolubly coupled with each other. Forces of vibration are spread in space with speed of light, interacting with polytrons in atoms and with free polytrons, and create the lively and active medium for everything, what can vibrate.
In dinosaur's times the Earth year and the Earth day were shorter, therefore now we live in the phase of negative angular acceleration. We guess, that the electronegativity of the Earth is conditioned by her uniformly slowed gyration.
The Earth is the huge gyroscope, which is charged by negative electricity. The gyration of electric charge generates some part of magnetic field of the Earth.
In order to test quantitatively this supposition it is necessary go to the "magnetic" history of the Earth. During the existence the Earth, her magnetic poles had turned over some times. Not so large energy is necessary for turn over of poles of the Earth. In any case, it is significant smaller than it is necessary for rotational displacement of our Earth gyroscope on 180 degrees. But if to assume, that at rotation of the solar system around of galactic center, we moving on an elliptic orbit, then the pattern becomes more–less actual.
At moving of celestial body on an elliptic orbit the rotary acceleration of the body changes the sign four times for each turnover. The period of revolution of the solar system around of center of our Galaxy is approximately equal of 240 millions years. Therefore, the period of revolution of the magnetic field of the Earth should be equal of 60 millions years.
The reality of the world, in which we live, is, that we are capable to feel and to meter with the help of instruments only three phenomena of the nature - space, time and force. The majority of other physical units of measurements should not be utilized in theoretical physics, because they bring in tangle to understanding of the existing theories and hamper development of new hypotheses.
The research of physical and mathematical legitimacies of interaction between different objects of the surrounding world is extremely fascinating occupation. But we never should forget about the main duty for the researchers.
This duty consists in the solution of secrets of the living substance.
The equations of the electrical, magnetic and mechanical moments are designed specially to search for the laws of living substance in the mathematical form.
More detailed information, how the reduced formula was obtained you will discover in my site
http://vlamir.nsk.ru/index.htm
in the works:
http://vlamir.nsk.ru/electricity_e.pdf
http://vlamir.nsk.ru/magnetism_e.pdf
http://vlamir.nsk.ru/inertia_e.pdf
http://vlamir.nsk.ru/dipole of speed_e.pdf
Where
in the works:
