On The Non Relativity Of Simultaneity
The discussion centers on the concept of simultaneity in the context of special relativity, specifically challenging the notion that simultaneity is relative. Participants explore the implications of length contraction and propose alternative interpretations of simultaneity, with a focus on the author's upcoming paper intended for resubmission to a journal.
  • The original poster argues that simultaneity is absolute and not relative, using the example of rulers in relative motion to illustrate their point.
  • Some participants challenge the assertion that the order of events must be universally correct, suggesting that relativity does not require such an assumption.
  • There is mention of an algebraic proof that could potentially show a contradiction in the original poster's argument, though the specifics of this proof are not provided.
  • Participants debate the assumptions underlying the original poster's argument, particularly regarding the validity of special relativity and the implications of length contraction.
  • One participant asserts that the contradiction presented only holds if both of the original poster's assumptions are accepted as true.
Participants express disagreement regarding the assumptions made in the original argument and the implications of simultaneity. There is no consensus on the validity of the claims made by the original poster or the counterarguments presented.
Participants highlight the dependence on specific assumptions regarding simultaneity and the interpretation of length contraction. The discussion remains unresolved with multiple competing views on the nature of simultaneity in special relativity.
TheAtheistKing
Hello everyone, I am new to this forum.
In oct 2000 I submitted a paper to the European journal of physics on the non relativity of simultaneity. Essentially, the paper didn't deal with the theory of relativity, so much as it did with the issue of simultaneity.
The paper was not published, however since that time I have expanded on my original paper, and focused more on the incorrectness of the relativity of simultaneity. I would like to discuss my work here, as I am preparing to resubmit the paper to the Journal. I would like to have some general reaction to the material that is going to be submitted to them.
The original paper didn't focus on time dilation, but rather it focused upon length contraction. There is a simple way to understand why length isn't relative, and the answer has to do with simultaneity.
The definition of an inertial reference frame is a frame in which Newton's laws are valid. Now, suppose that F1 is an inertial refefence frame, and F2 is moving at a constant speed relative to F1. It will follow that F2 is also an inertial reference frame.
Now consider a ruler R1 at rest in some inertial reference frame F1. There are no forces acting upon this ruler, because we have stipulated that it is at rest in this frame i.e. v=0. Now, suppose that another ruler R2 has an identical length to R1, if the rulers are at rest with each other. Thus, the ends of the rulers can be made to 'coincide' as illustrated below:
R1: A......B
R2: A`......B`
Now, suppose that the same two rulers are now in uniform relative motion to each other, so that each is still in an inertial reference frame. They are now in relative motion, and the relative speed is v.
Assumption 1: The Lorentz Fitzgerald length contraction formula is true.
Consider things now from the point of view of ruler 1 at rest and ruler two moving from right to left as illustrated below. Ruler 2 is length contracted as shown below:
Initial state
R1: A......B
R2:______________A`...B`
Inermediate state
R1: A......B
R2: _________A`...B`
Final state
R1: A......B
R2: A`...B`
As you can see, the order of states is very clear. B coincides with B` BEFORE A coincides with A`.
Now consider things from the point of view of ruler 2 at rest and ruler 1 moving from left to right as illustrated below. In this frame ruler one is length contracted, and the order of states is shown below:
Initial state
R1:A...B
R2:______A`......B`
Intermediate state
R1:______A...B
R2:______A`......B`
Final state
R1:_________________A...B
R2:______A`......B`
As you can see, A coincides with A` before B coincides with B`.
Thus, if assumption 1 is true, then there are different states of the universe X,Y, such that X before Y AND Y before X. This should be regarded as impossible, and thus SR can be overthrown without having to think about the time dilation formula at all. This then is the basis of my approach to toppling the theory of special relativity.
The proper conclusion is that the ends of the rulers coincide simultaneously in all reference frames, not just inertial reference frames. In other words simultaneity is absolute, not relative.
I think this is enough to start off the discussion. At the very least, this should help you understand how come the conclusions of SR are so weird. My current paper goes into clock rates, inertial reference frames, synchronicity, location of measurements in a frame, derivation of the length contraction formula and time dilation formula using the basic postulate of SR which is that the speed of light is the same in all inertial reference frames, and a few other things which could be regarded as new. I refer to the new theory as state theory, and regard it as the only alternative to relativity theory.
I will start the thread by asking a question. Who here understands the logic of my argument, which is that we needn't worry about the time dilation formula in our approach to overthrowing SR?
Thanks
Originally posted by TheAtheistKing
This should be regarded as impossible, and thus...
unfortunately, we cannot just say "this should be impossible".
The problem you described is only a problem if we assume there exists some universal "correct" order that events happen. But this is not an assumption we make in relativity.
Fortunately an algebraic proof can be constructed.
We don't need to assume anything other than lorentz contraction, in order to arrive at an algebraic contradiction.
You are wrong again, since you don't need to assume anything other than lorentz contraction, in order to arrive at an algebraic contradiction.
This isn't an algebraic contradiction. Algebra doesn't say anything about "simultaneity should work this way". In fact, algebra doesn't say anything about time at all.
What I've shown you here can be converted into an algebraic argument, and there will be a clear contradiction. I didn't say this was the algebraic argument, only that there is one.
But all that will show is that one of your assumtions is false. In order to overthrow SR that way, you need to assume only special relativity. But that wasn't the only assumption you made.
You aren't following the logic of my argument correctly. Here is the argument form I use:
If X then (Y and not Y); therefore not X
where X is the length contraction formula. I only use SR, binary logic, and algebra in the proof. You have not seen the algebraic proof yet. You are making false statements about my assumptions.
Look at the issue the following way.
Let A denote the length contraction formula, and let B denote the time dilation formula, now consider the following fact taken from binary logic:
If A and B then A
So if we can show that "if A then (X and not X)" SR is overthrown.
Hence the time dilation formula need never be assumed, in order to overthrow SR, and certainly SR uses binary logic and algebra, so they can be considered assumptions of SR as well.
You really should just say you want to see this supposed algebraic proof that simultaneity is absolute and not relative, rather than simply cling to a very misguided theory. Additionally, I am glad you are interested in the topic.
I understand the logic you're using. But you're making two assumptions, not one. You're assuming:
1. That SR is true.
2. That if A and A' coincide before B and B' in one inertial reference frame, it cannot happen the other way around in another inertial frame.
The contradiction you've shown is only a contradiction is you assume both 1 and 2. But that only proves that either 1 or 2 is false.
I understand the logic you're proving. But you're making two assumptions, not one. You're assuming:
1. That SR is true.
Ok, now we are getting somewhere. The state diagrams which you looked at aren't an argument, they are state diagrams. However, what I am saying is that we can quickly see what it is about common sense that the theory of relativity contradicts. In other words, the state diagrams lead to a clear algebraic argument, the diagrams themselves aren't the argument. Succincly put, the algebraic argument doesn't make assumption two above. Here, I will give you a clue. In the algebraic argument, only one state diagram is used and it is this:
Initial state
R1: A...B
R2:_____A`...C.....B`
Intermediate state
R1:_______A...B
R2:_______A`...C...B`
Final state
R1:__________________A...B
In that case, I would certainly like to see that algebraic argument.
However I should mention that just about everyone who understands relativity knows that it contradicts most common sense. But common sense is a guide, not the absolute truth. And since relativity works better than any other theory we currently have, we use it.
If SR ends in contradiction then no one undestands SR.
It will take me a lot of time to post the algebraic proof here, because I don't know how to place mathematical symbols here.
P.S.: Really, we have a decision that doesn't seem to be able to be made by the physics community, and that decision is on whether or not simultaneity is absolute or relative. The issue has remained unsettled for years, and without rigid adherence to binary logic, the issue can never be resolved.
[BIf SR ends in contradiction then no one undestands SR.[/B]
But it only contradicts common sense, not itself.
Common sense is just a heuristic that evolved to help humans make quick decisions that are accurate most of the time. It may not be possible to replace relativity with a theory that doesn't contradict common sense. Unless you're willing to sacrifice accuracy.
Forget about common sense, I am telling you if the lorentz contraction formula is true, then you can derive a contradiction algebraically. This has nothing to do with common sense whatsoever, the contradiction can be made explicit, or as you would say "SR can be shown to self contradict".
Most physicists agree that simultaneity is relative. Particularly since this is a requirement of SR. If SR didn't agree with the evidence the way it does, people would probably prefer to throw it away and assume simultaneity is aboslute.
As I said, I would have to see that. It might be easier for you to post it if you use LaTeX.
What does it matter if they all agree, if SR ends in contradiction?
What conclusive evidence is there that SR is correct? The experiment which must be done to determine whether or not simultaneity is absolute is well known to be beyond our current ability to experimentally determine. No physicist wants to assume simultaneity is absolute, and no physicist wants to assume simultaneity is relative, they want to know which it is.
What conclusive evidence is there that SR is correct? The experiment which must be done to determine whether or not simultaneity is absolute is well known to be beyond our current ability to experimentally determine. No physicists wants to assume simultaneity is absolute, and no physicists wants to assume simultaneity is relative, they want to know which it is.
Of course, we don't know SR is correct, in any absolute sense. But we do have evidence, like the fact that the GPS works, to indicate that it is, as far as we know, accurate.
Since we need simultaneity to be relative for SR to work, we accept that it is. If someone comes up with a better theory than SR that requires absolute simultaneity, well use that. But currently, the theory that requires relative simultaneity gives the best results.
As for SR having a contradiction, I'll believe that when I see it.
Since we need simultaneity to be relative for SR to work, we accept that it is...
Ok, it is time for the proof, but It's going to be hard to get it all out on this thing. How about if you and I slowly go through the argument one piece at a time. I will post a little, and then you comment on whether you are following the argument so far. Let me start off the algebraic argument.
Consider two rulers which have identical lengths when at rest, which are now in uniform relative motion with speed v. Let the length of either ruler at rest be denoted by L0, and let the length of either ruler in relative motion be denoted by L. Let c denote the speed 299792458 meters per second.
Assumption 1: L=L0(1-v^2/c^2)^1/2
Consider an event where the rulers move by each other. The event is to begin with the universe in the following state:
R1:A...B
R2:____A`......B`
This state is characterized by the end B of ruler one coinciding with the end A` of ruler two.
Now, suppose there is a clock stationed at A`. An observer there can clearly note his clock reading when B passes by. Later on, the point A will pass by him, and he can again note what his clock reads. He will thus have made two readings, one reading made before the other. Suppose his first reading is x, and that his second reading is y, on a digital clock. Since the clock isn't being subjected to any forces, let us say that this single clock can make an inertial time measurement Delta t of the event which begins when B coincides with A` and ends when A coincides with A`. The time of the event as 'inertially' measured is:
Delta t = y-x
Do you follow the argument so far?
Yes.
R1:A...B
R2:____A`......B`
(the rest of the argument insert here)
Delta t = y-x
Ok so, in time Delta t, the point A has moved some distance in this frame. The question now, is what is this distance? Well, in time delta t, the entire ruler 1 has moved by A, so that the distance traveled MUST be L (by assumption that lorentz formula is true). Hence the speed of A relative to A` is:
Vaa` = L/delta t
Any questions so far?
No. It's still good.
R1:A...B
R2:____A`......B`
Delta t = y-x
Vaa` = L/delta t
If ruler one has length contracted, then in this frame the point B on ruler one coincides with some point C` on ruler two as follows:
R1:____A...B
R2:____A`...C`.....B`
Now, the location of the point C` relative to A` must be as follows:
The distance between A` and c` is equal to L. This is so because we have assumed that the Lorentz Fitzgerald length contraction formula is true. And by simple algebra, the distance from C` to B` is none other than L0-L.
Still following?
Still following?
Yes
R1:A...B
R2:____A`......B`
Delta t = y-x
Vaa` = L/delta t
R1:____A...B
Let me change notation here and instead of writing delta t for the time let me write delta t1. So, in this frame thus far, the point B is located in the middle of ruler two, it coincides with the point C`, and the time this has taken as measured by a stationary clock located at A` is delta t1.
Ok now here is what to do next. Consider things onward from C`. So we have a state in which B coincides with C`. We are now interested in the time it will take the point B to reach the point B`. Let us denote that time by delta t2, therefore in time delta t2, the point B will have traveled a distance L0-L so that it now coincides with B`. The speed of B relative to B` is
Vbb` = (L0-L)/delta t2
Ok so far?
Ok so far?
I think so.
Ok so far?
I think so.
Ok let's do this again. We have an event, it begins when B coincides with A`, and ends when B coincides with B`. Now this event is going to take some amount of time according to clocks at rest in ruler two's frame.
So let us say that we have three clocks, one stationed at A`, another stationed at C`, and a third stationed at B`. As the point B moves along ruler two, observers stationed at the clocks can make readings.
Now, let us assume that all three clocks have identical readings when the event begins, thus they are synchronized. So for simplicity, let all three clocks read zero, at the exact moment when B coincides with A` (which is the beginning of the event).
Now, as the point B moves along ruler two, all three clocks will be ticking. Let us suppose that all three clocks are of identical construction, therefore they all tick at the same rest rate. So let us suppose that at the moment when B coincides with C`, that the clock stationed at C` reads r. Well, since all three clocks tick at the same rate, and since they were synchronized when the event began, they are still synchronized. This means that when B coincides with C` all three clocks read r.
So eventually, the point B will coincide with B`, and a clock reading there can be made. Suppose that reading is h. Thus, the time it took for the point B to move from C` to B` is :
delta t2 = h-r
Are you still there?
Yes. I went back over it. I understand what you're saying.
[tex]v=\frac{L}{\Delta t_1}=\frac{L_0-L}{\Delta t_2}[/tex]
Let me clean up the notation for you and me.
Here is the state diagram (for help):
Initial state
R1: A...B
R2:_______A`...C`...B`
Intermediate state
R1:_______A...B
Final state
R1:______________________A...B
Focus on the time it takes for B to move from A` to B`. Let us agree to denote that time by delta t`. Thus, the total time of the event is being denoted by delta t`. In fact, let us agree to refer to all measurements or computations in the primed frame using a prime symbol. Now, the whole event is composed of two sub events. The first sub event begins when B coincides with A` and ends when B coincides with C`, and the second sub event begins when B coincides with C` and ends when B coincides with B`. Let the time of the first sub event be denoted by delta t1`, and let the time of the second sub event be denoted by delta t2`. Thus it follows that:
delta t` = delta t1` + delta t2`
Do you understand the forumla above?
Do you understand the formula above?
Yes.
Ok I really really need to know how to make those math symbols, then this will be simple, can you explain that to me?
I'm reading the PDF file on latex now.
What would I type to write
Delta t
Using the symbol for delta?
  • · Replies 32 ·
  • · Replies 17 ·
  • · Replies 36 ·
  • · Replies 20 ·
  • · Replies 35 ·
  • · Replies 221 ·
18K
  • · Replies 16 ·
  • · Replies 18 ·
