Impulse in a flywheel-to-flywheel situation
  • Thread starter Thread starter swedish_lunacy
    Impulse
The discussion centers on the calculation of maximum torque output when connecting two flywheels instantaneously. It concludes that while theoretical models suggest torque could approach infinity with zero coupling time, real-world limitations such as material rigidity prevent this from occurring. The conversation emphasizes that high stress environments lead to material deformation, which ultimately limits torque output. Therefore, practical applications must consider the physical properties of materials involved.
  • Understanding of angular momentum and torque principles
  • Familiarity with material rigidity and deformation under stress
  • Knowledge of collision dynamics and peak force generation
  • Basic physics concepts related to flywheel mechanics
  • Research the effects of material properties on torque output in mechanical systems
  • Explore the principles of angular momentum conservation in flywheel systems
  • Study real-world applications of flywheel energy storage systems
  • Learn about the limitations of instantaneous torque in mechanical engineering
Mechanical engineers, physicists, and students studying dynamics and torque in rotational systems will benefit from this discussion.
swedish_lunacy
Cognitive superiors,
I am trying to calculate the maximum torque that a flywheel of a given angular momentum can output when "instantaneously" ( I think this is my problem ) connected to another flywheel.
From what I can see it seems that as the time taken to couple the flywheel to the output shaft approaches zero, the torque output approaches infinity.
Does this mean that you can essentially create a huge, huge torque from "instantly" coupling a small flywheel to something ? Seems wrong to me.
Taking a real workd situation. If I was trying to grab a large moving flywheel it would try to rip my arm out of it's socket, if I were to grab a small moving flywheel such that the contact-time produces the same maximum torque then I may be able to stop it ? Or is this more to do with work than torque ?
Cheers
Nick
The instantaeous torque does indeed go to infinity. As with many other physical procesees, that typically means that some assumptions that you're making are probably invald (in this case rigidity).
In real life, there is a limit on how rigid materials are, and they will deform in high stress enviroments. With the right equipment, I'm sure you could twist a heavy I-beam without any restraints other than the I-beam's intertia.
Similarly, colisions can produce spectacularly large peak forces, but at some point the materials involved will fail in a variety of ways.
Gotcha, ie. no material is infinitely rigid therefore no torque is ever infinitely large.
Thanks
Nick
  • · Replies 43 ·
  • · Replies 60 ·
20K
11K
  • · Replies 86 ·
11K
