How do I attemp such a Question?
  • Thread starter Thread starter ilovephysicssomuch
The discussion revolves around a physics problem involving a horizontal string that transmits power through waves. The original poster seeks to understand how folding the string into a "double string" configuration affects the maximum power transmitted while maintaining constant tension.
  • Participants explore the implications of folding the string on its mass per unit length and length. Questions arise about how these changes affect power transmission and whether certain variables, such as wave speed, also change.
There are various interpretations of how the folding affects the string's properties. Some participants suggest reconsidering the relationship between the doubled string and its power transmission capabilities, while others express uncertainty about the correctness of their calculations and assumptions.
Participants note the urgency of the assignment deadline, which adds pressure to the discussion. There is also mention of differing interpretations regarding the effects of folding the string versus using two separate strings.
ilovephysicssomuch
:confused: Can someone please help me?
A horizontal string can transmit a maximum power (without breaking) if a wave with amplitude A and angular frequency is traveling along it. To increase this maximum power, a student folds the string and uses this "double string" as a medium. Determine the maximum power that can be transmitted along the "double string" assuming that the tension is constant.
You should really show some of your own work and ideas before asking a question in the homework section but I'll give you a hint: While the tension remains the same, both the length and the mass per unit length change. :)
If the string is being folded would its mass per unit length double and its length would decause by 1/2?
Hi, I need the help with the same problem,
Well I know that Power is equal to P = 1/2 (u)(w)^2(A)^2(v). And when string is doubled the tension stays the same and length is reduced by half and the mass per unit length is increased by two. So the new equation becomes: P = 1/4(u)(w)^2(A)^2(v). Is this a right answer? Or should I have done it somehow differently? Does v changes as well or stays the same?
Thanks
well..
That's wrong.. replace v by another equation and start from there.. the rest will just follow through.. Isn't your assignment due today at 1?
is due at 1pm or 9am?
Anyway what I got when string is doubled is
aplitude = A/2
Mass per unit length = 2u
speed =(T/2u)= 2^-0.5 v
angular frequence =2pi/9T/2) = 4pi/T = 4pi f
period = T/2
tension =4
P 1/2 (2u) (2pi f)^2 (A/2)^2 (2^-0.5 v) = u 16 (pi f)^2 (1/4) A^2(2^-0.5 v) = (2^-0.5)( u)(w^2)(A^2)(v)
you are making your life complicated... this question is doable according to your prof. You are thinking too hard.. it's a really simple question. you are messing with too many variables. just think about what the doubling is affecting.. sorry I cannot help.. I have class to get to.
I agree. I don't think the half-length thing is part of the solution. The important thing is that the string is *doubled*. Hint -- is there a difference between doubling the string and running two separate strings? Unless you braid the two strings or something, I would think not. And if not, then how much more power can you transmit using two separate strings...?
  • · Replies 23 ·
  • · Replies 19 ·
