I have some balls that have not been opened
  • Thread starter Thread starter Mk
    Balls
The discussion revolves around the methods and safety considerations for cutting open golf balls. Participants share personal experiences, safety warnings, and various techniques, exploring both the historical and contemporary construction of golf balls.
  • One participant suggests using a knife to cut open a golf ball but expresses concern about safety, particularly regarding cutting fingers.
  • Another participant advises against attempting to cut the ball without proper tools like a vise or saw, emphasizing the need for safety.
  • Some participants share anecdotes about cutting open golf balls in the past, describing different materials found inside, such as rubber bands or resin jelly.
  • A participant mentions that modern golf balls are likely made with different materials compared to those from thirty years ago, noting advancements in composite technology.
  • There are warnings about potential pressure buildup inside golf balls, with one participant stressing the risk of injury if not handled properly.
  • Several participants joke about the situation, with one humorously suggesting that the original poster should play with the balls until they need glasses.
Participants generally agree on the importance of safety when cutting open golf balls, but there are differing opinions on the best methods and tools to use. Some share personal experiences that conflict with others' warnings, leading to an unresolved discussion on the safest approach.
There are references to varying constructions of golf balls over time, with some participants recalling older designs that may not reflect current manufacturing practices. The discussion also highlights the lack of consensus on the presence of pressure within golf balls.
Mk
I have a golf ball that I want to cut open. How do I go about doing this? Just use a knife? I don't want to cut my finger open! What do I do!?
Don't do anything.Hey look at the google ads! "Golf equipment", "Distance golf balls", "Golf balls - huge range".
I just see balls all over my screen.
I think Tribdog might be able to help you out with this.
Put the golf ball in a vise and then use a saw to cut it.
What if I don't have a vise? Or a saw?
You're not going to cut it without some type of saw.
Then don't do it. You need a vise. Ok, don't do it. trib can send you one already cut open.
I'll try and open it with my sander.
Mk said:
Balls all over my screen
TheStatuaryApe said:
I think Tribdog might be able to help you out.
Mhmm, I see.
NOOOOOO.
I believe there may be some pressure built up, or maybe that was the old balls, but YOU COULD PUT AN EYE OUT. DON'T DO IT.
I was just kidding. I don't even have a sander.
There's no built-in pressure. I've split a couple with the mere use of my miserable swing. The core of the last one I split this way is a hard composite, and this particular one was was pink. Thirty years ago some balls were made of what looks like rubber bands at maximum stretch and all coiled up tightly. I don't think they do this anymore, it's too time consuming and new composites just work better. Use a sharp knife to cut through the outer casing and you will find a solid core. Come back and tell us what color.
Somebody I talked to said when he was a kid he would cut open golf balls with a knife. There was some sort of rubber band ball inside, and he would unwind it, and put it across the road. Sometimes there was some kind of resin jelly inside.
I cut golf balls open as child. Yes, it had an elastic band inside, which unravelled rather amusingly and animatedly. Today, I'm sure they're made differently.
Do not attempt to cut it with your hands and a knife, you will surely lose a digit. Go to freinds or family who have a hacksaw and vise.
Evo said:
NOOOOOO.
Can he at least play with his balls until he needs glasses? :-p
He said he used a pocket knife and made very shallow cuts so as not to cut the rubber bands. He still has all 20 digits.
9K
  • · Replies 40 ·
