Using Salt Peter as gasoline improver.
  • Thread starter Thread starter dmz
    Gasoline Salt
The discussion centers on the use of Salt Peter (potassium nitrate, KNO3) as a gasoline improver. Participants conclude that mixing KNO3 with gasoline does not yield significant performance benefits due to its low solubility in hydrocarbons. Concerns about potential explosions in the gas tank are addressed, indicating that clogging of the gas line from undissolved salt is a more likely issue than an explosive reaction. Overall, the mixture is deemed ineffective for enhancing gasoline performance.
  • Understanding of chemical properties of potassium nitrate (KNO3)
  • Knowledge of gasoline composition and behavior
  • Familiarity with solubility concepts in chemistry
  • Basic principles of combustion and oxidation
  • Research the chemical properties of potassium nitrate and its applications
  • Explore alternative gasoline additives for performance enhancement
  • Learn about the solubility of various compounds in hydrocarbons
  • Investigate safety protocols for handling oxidizers and flammable materials
Automotive engineers, chemists, and hobbyists interested in fuel performance and safety considerations in fuel modifications.
dmz
Well i read that Salt Peter is a strong oxydizer (sorry about my english) so i thought that if I mix it with gasoline then i should get more power out from my car. But won't the mixture of gasoline and saltpeter explode in the gas tank?
Chemistry news on Phys.org
The solubility of KNO3 in hydrocarbons is quite small; you won't get enough into solution to give you any significant effect. Explode in the tank? You'll be looking at clogging of the gas line from undissolved salt before you get to any sort of "explosive" mixture proportions. Thinking of blowing up someone else's car? The initiator requirement for detonating gasoline-KNO3 is probably greater than the explosive yield of the mixture itself.
Hmmm. 18-crown-6?
  • · Replies 20 ·
  • · Replies 33 ·
60K
  • · Replies 21 ·
  • · Replies 17 ·
35K
  • · Replies 27 ·
17K
24K
47K
