Understanding the Two-Twist Mechanism in Lamps: The Science Behind Its Design
  • Thread starter Thread starter pi-r8
The discussion revolves around the design of lamp knobs that require two twists to operate, exploring the mechanics behind this feature and its implications for different types of light bulbs. The scope includes technical explanations and conceptual clarifications regarding lamp functionality.
  • Technical explanation, Conceptual clarification, Debate/contested
  • One participant notes that most lamps require two twists of the knob to turn on and off, questioning the necessity of this design.
  • Another participant claims to have a lamp that only requires one click, suggesting that two-click knobs might be part of a conspiracy.
  • A participant explains that some lamp fixtures are designed for 2-way and 3-way bulbs, which can affect how many clicks are needed to activate the bulb, depending on its wattage.
  • Another participant describes a mechanism involving two filaments (40-watt and 60-watt) that corresponds to the different positions of the switch, indicating that each click activates a different filament or combination of filaments.
  • A later reply expresses gratitude and indicates that the explanations provided make sense to them.
Participants express differing views on the necessity and functionality of the two-twist mechanism, with some providing explanations while others question the design. No consensus is reached regarding the overall effectiveness or rationale behind the two-click system.
Some assumptions about bulb compatibility and fixture design are present, but these are not universally agreed upon. The discussion does not resolve the implications of using different wattage bulbs in relation to the knob's functionality.
pi-r8
On most lamps that I've come seen, they have a round knob that you rotate to turn the lamp on and off, and it clicks when you do that. Every one of those lamps requires TWO twists of the knob to do anything (two to turn it on, another two to turn it off). Why do they make them that way? Wouldn't it be easier to just turn it once?
I only have one of these lamps in the house. It only takes one click. Two-click knobs are obviously a conspiracy.
The reason for this is that some lamp fixtures are pre-designed to house 2-way and 3-way bulbs. What this means is that those types of light bulbs have either 2 or 3 illumination settings. This is common in house lamps.
Now, if you place a standard bulb into one of those fixtures, often only the last "click" will turn on the bulb if the bulb watt ratting is high(say, 68-watts)
If you placed, say, a 40-watt standard bulb into one of those fixtures, the first "click" might light the bulb.
I have only noticed 2 clicks to do anything. Every other click actually does something. The way it works is there are 2 filaments. One 40 and one 60 watt filament. The first position on the switch neither filament is energized. The second position only the 40 is energized. The third position only the 60 is energized. The last position both are energized for 100 watts.
Thanks guys. It makes sense to me now.
  • · Replies 19 ·
