Understanding the Relationship Between Nozzle Size and Fire Extinguishing Power
  • Context: Undergrad
  • Thread starter Thread starter eosphoro
    Reaction
The discussion centers on the relationship between nozzle size and fire extinguishing power, specifically how reducing nozzle diameter increases the reaction force from a pump. It is established that while halving the nozzle size theoretically doubles the force of reaction, practical limitations arise due to frictional forces that impede fluid flow at smaller diameters. The conversation highlights that this phenomenon is significant for nozzle sizes larger than 2 cm, where frictional forces, including viscosity and van der Waals forces, become substantial enough to counteract the pressure generated by the pump.
  • Understanding of fluid dynamics and pressure principles
  • Knowledge of viscosity and frictional forces in fluids
  • Familiarity with fire extinguishing systems and their components
  • Basic principles of pump mechanics and operation
  • Research the effects of nozzle diameter on fluid flow rates in fire extinguishing systems
  • Study the principles of viscosity and its impact on fluid dynamics
  • Examine the role of frictional forces in fluid mechanics
  • Explore advanced pump designs and their efficiency in fire suppression applications
Fire safety engineers, fluid dynamics researchers, and professionals involved in designing fire extinguishing systems will benefit from this discussion.
eosphoro
my teacher on fire estinguising subject explained me that with the same pump if you reduce the size of the nozle you increase reaction on the fire stinguisher
so does reaction depend on cinetic energy sent away?
but if by halving the nozle you get double force of reaction with the same pump, can't you half the nozle infinitally with ideal materials and fluid, and double the force of reaction infinitally
then what would avoid you from using this force of reaction to feed the pump since this force in theory can be infinite by making the nozle infinitesimal (this is what i understand from my teachers explanation)
I like your thinking.. The theory of halving nozzle size and doubling pressure or force of reaction works only for sizes bigger than some limit say 2cm in diameter.
Apart from pressure from inside, the liquid/gas flowing in the air will be expering friction-type forces on the walls of the nozzle
When we reduce the diameter of nozzle, these frictional forces will be huge and they will overcome the pressure. and will stop the liquid coming out.
You can try this will a syringe/injection. Without the needle, water comes fast, with needle it takes some time because the needle is so thin that it have more friction-force against liquid coming out. (these forces are also called vanderwall forces and property is called viscosity)
  • · Replies 51 ·
38K
9K
