What is Hybridization and How Can It Be Calculated Using a Simple Technique?
  • Thread starter Thread starter dnt
    Chem
The discussion revolves around the concept of hybridization in chemistry, specifically how it can be calculated and understood in relation to central atoms. Participants explore electron dot structures, Lewis structures, and the application of hybridization in various molecular contexts.
  • One participant inquires about the correct way to draw electron dot structures for carbon, specifically whether to distribute valence electrons evenly or cluster them.
  • Another participant suggests that valence electrons should be placed one on each side of the atom until all are used, indicating a method for drawing electron dot structures.
  • Discussion includes references to hybridization types such as sp, sp2, and sp3, with some participants expressing confusion about determining hybridization around central atoms.
  • One participant emphasizes the importance of understanding standard rules and principles, such as the Pauli exclusion principle and minimizing electron repulsion in VSEPR theory.
  • A participant provides a technique for calculating hybridization by considering the total number of electron pairs around the central atom, using ammonia (NH3) as an example to illustrate the concept.
  • Another participant shares a quick calculation method for determining hybridization using the total valence electrons of carbon and hydrogen in a compound, providing a formula and a table for reference.
The discussion contains various viewpoints on how to approach hybridization and electron dot structures, with no consensus reached on a single method or understanding. Participants express differing levels of familiarity and clarity regarding the topic.
Some participants express confusion regarding hybridization and electron pair counting, indicating a need for further clarification on these concepts. The discussion does not resolve the uncertainties surrounding the methods for determining hybridization.
dnt
1. if you want to draw the electron dot structure for say carbon (4 valence electrons) would you draw it with one dot on each side or two on one side, and one on two other sides?
2. can someone give me a link that helps discuss hybridization - i don't really get it and i need help understanding it and trying to figure it out around central atoms. thanks.
1. You would put one on each side. You have to add one to each side until you're out of valence electrons so everything is balanced. ^_^
2. I'm not really sure what that is...
like sp2, sp3, etc...stuff like that.
most of it is just standard rules. Try to pick up on the main concepts, such as the pauli exclusion principle and apply it. If you're working with VSEPER note that minimizing electron repulsion is one of the main themes.
im pretty good at drawing lewis structures and naming the shapes but i don't quite get how to determine the hybridization around the central atom.
It's been a while since I did this but this website gave a decent review on hybridization
http://chemistry.boisestate.edu/rbanks/inorganic/bonding%20and%20hybridization/bonding_hybridization.htm
for determining hybridization, take into account the total electron pairs around the central atom, they maybe bond pairs, or lone pairs, the number of electron pairs is equal to the total number of hybridized orbitals (using pauli's exclusion principle, an orbital can't have more than 2 electrons with opposite spins)
confused? let's make it all clear with a couple examples
first we take up NH(3) (Ammonia)
Now, the central atom in ammonia is nitrogen, which has five valence electrons, three of them are shared by the hydrogens, and two are left unshared.
So the total number of Electron Pairs? There are 3 bond pairs and a lone pair, which makes the number 4, which means there are four hybridized orbitals.
Which Hybridization has 4 orbitals? sp3.
I hope this helps you, if there are any further questions, ask away.
i would like to add to aalmighty...
this a small technique to calculate the hybridzation quickly.
for example take [tex]CH_4[/tex],
add Carbons' 4 valence electrons with the total number of valence electrons in all the hydrogen in the compound and divide by 2 ,
[tex]\frac{4+4}{2}=4[/tex]
there four hybrid orbital hence it is sp3
similarly you can use this technique for other compounds also but when you have Oxygen or bivalent elements in the second place just ignore them and when you have ions take into consideration the no of electrons lost(cations) or gained(anions) by the chemical species.
here is some table that might help you
if there are 2 hybrid orbitals it is sp hybridized
if there are 3 hybrid orbitals it is sp2 hybridized
if there are 4 hybrid orbitals it is sp3 hybridized
if there are 5 hybrid orbitals it is sp3d hybridized
if there are 6 hybrid orbitals it is sp3d2 hybridized
if there are 7 hybrid orbitals it is sp3d3 hybridized
13K
11K
9K
