The Minimum Speed Necessary for a Scramjet to Operate
  • Thread starter Thread starter |Orion's Thought|
    Minimum Speed
The discussion revolves around the minimum speed necessary for a scramjet to operate effectively. Participants explore the principles of scramjet technology, its differences from ramjets, and the implications of speed on performance, with references to experimental data and ongoing research.
  • Experimental/applied
  • Some participants assert that scramjets mix fuel with compressed air at supersonic speeds, but there is confusion about the minimum operational speed.
  • One participant suggests that the lack of consensus on minimum speed is due to scramjets being experimental and possibly classified.
  • Another participant highlights the distinction between scramjets and ramjets, noting that scramjets operate at supersonic speeds while ramjets operate at subsonic speeds.
  • A later reply mentions that scramjets can operate at Mach numbers of 6-8, but the lower limit depends on the definition of a scramjet, with some designs transitioning from ramjet to scramjet between Mach 3-6.
  • Concerns are raised about nozzle design and performance at varying Mach numbers, indicating that optimal geometry is crucial for effective operation.
  • One participant references a recent test of the Hyshot III scramjet, claiming it reached speeds of Mach 7.6, and mentions that scramjets do not function until reaching five times the speed of sound.
Participants express differing views on the minimum speed for scramjet operation, with some suggesting it is around Mach 5 while others indicate it can be lower depending on specific designs. The discussion remains unresolved with multiple competing perspectives.
Participants note that definitions and operational parameters for scramjets may vary, and there are unresolved questions regarding the physics of shock waves and nozzle design impacting performance at different speeds.
|Orion's Thought|
The basic principle of a scramjet is to mix fuel with compressed air going supersonic speeds with relatively few or no moving parts. What I'm wondering is what the minimum speed the scramjet has to be moving to work properly. I've been looking on the web at numerous places, but no place gives me the same answer.
http://www.jhuapl.edu/areas/sciencetech/Propulsion/RamjetsScramjets.asp
http://www.jhuapl.edu/newscenter/aplnews/2002/hyfly.asp
That's becasue they're still experimental and probably a well-guarded secret.
You might be confusing a ramjet with a scramjet. There is a big difference between the two.
In that case, I stand with him in the "confused" camp. I was my understanding that a scramjet is, literally, a supersonic ramjet.
And ... (hang on) ... it would appear that Wikipedia is in our camp too:
"A scramjet (supersonic combustion ramjet) is a variation of a ramjet where the flow of the air and combustion of the fuel air mixture through the engine is done at supersonic speeds. This allows the scramjet to achieve greater speeds than a conventional ramjet which slows the incoming air to subsonic speeds before entering the combustion chamber."
Definitely check out the Wikipedia article mentioned by Dave, but it will not answer the original question. - http://en.wikipedia.org/wiki/Scramjet
Secondly, the heating of the gas by combustion causes the speed of sound in the gas to increase (and the Mach number to decrease) even though the gas is still traveling at the same speed. Forcing the speed of air flow in the combustion chamber under Mach one in this way is called "thermal choking". It is clear that a pure scramjet can operate at Mach numbers of 6-8, but in the lower limit, it depends on the definition of a scramjet. Certainly there are designs where a ramjet transforms into a scramjet over the Mach 3-6 range (Dual-mode scramjets). In this range however, the engine is still receiving significant thrust from subsonic combustion of "ramjet" type.
The issue is that the nozzle design optimized for the high Mach range doesn't perform as well in the subsonic or low Mach range. The optimal geometry has to be tailored based on the physics of the shock waves in the inlet. The details may be available from NASA.
See also - http://en.wikipedia.org/wiki/Hyper-X
When I first read this, I immediately thought that the question was saying "...mix fuel with compressed air WHILE going supersonic speeds." I had to reread the post to see that he meant that the airflow was indeed supersonic. I stand corrected. The only confused one here is me.
Sorry Fred, I should have worded that better.
Found some useful and otherwise cool stuff! :cool:
Rocket propulsion - http://exploration.grc.nasa.gov/education/rocket/shortr.html
Low hypersonic - http://www.grc.nasa.gov/WWW/K-12/airplane/lowhyper.html
High hypersonic - http://www.grc.nasa.gov/WWW/K-12/airplane/hihyper.html
Engine inlets - http://www.grc.nasa.gov/WWW/K-12/airplane/inlet.html
Ramjet/scramjet thrust - http://www.grc.nasa.gov/WWW/K-12/airplane/ramth.html
Scramjet - http://www.grc.nasa.gov/WWW/K-12/airplane/scramjet.html
Simulation software - http://www.cfdrc.com/bizareas/aerospace/propulsion/sim_analysis.html
Revolutionary jet engine tested - Hyshot III
A new jet engine designed to fly at seven times the speed of sound appears to have been successfully tested.
The scramjet engine, the Hyshot III, was launched at Woomera, 500km north of Adelaide in Australia, on the back of a two stage Terrier-Orion rocket.
Once 314km up, the Hyshot III fell back to Earth, reaching speeds analysts hope will have topped Mach 7.6 (9,000km/h).
It is hoped the British-designed Hyshot III will pave the way for ultra fast, intercontinental air travel.
Rachel Owen, a researcher from UK defence firm QinetiQ, which designed the scramjet, said it looked like everything had gone according to plan.
BBC Science News - http://news.bbc.co.uk/2/hi/science/nature/4832254.stm
http://news.bbc.co.uk/2/hi/science/nature/4832254.stm#graphic
Scramjets do not work until they reach five times the speed of sound
See related thread - Mach 10 - https://www.physicsforums.com/showthread.php?t=52355
Other links -
Hypersonics at University of Queensland - http://www.uq.edu.au/hypersonics/
QinetiQ - http://www.qinetiq.com/
Australia's Defence Scientific and Technology Organisation - http://www.dsto.defence.gov.au/
  • · Replies 39 ·
