Urr, this doesn't seem like it should be very hard but well, good 'ol me
  • Context: Graduate
  • Thread starter Thread starter schattenjaeger
    Hard
The discussion revolves around calculating the fraction of visible light within the electromagnetic spectrum of astrophysical relevance, specifically between 1m and 10^-3nm. Participants explore both linear and logarithmic scales for this calculation, as well as deriving Wien's displacement law.
  • Homework-related
  • One participant proposes calculating the fraction of visible light by dividing the range of visible light (approximately 3 x 10^-7m) by the total range of the electromagnetic spectrum (1m to 10^-3nm), suggesting a linear approach.
  • Another participant clarifies that taking the logarithm of a number less than one results in a negative value, which is acceptable in logarithmic calculations. They suggest expressing the entire range of wavelengths in "log meter" units to determine the range spanned by visible light.
  • There is a discussion about deriving Wien's displacement law by setting the derivative of a specific function to zero, with one participant questioning if solving for lambda*T would be the correct stopping point.
  • One participant reports obtaining a result of about 2 percent for the logarithmic scale calculation and questions if the linear scale result of 3 x 10^-5 percent is accurate.
Participants express uncertainty about the calculations and methods, with no consensus reached on the final results or the approach to deriving Wien's displacement law.
Participants express varying levels of confidence in their mathematical skills and understanding of logarithmic scales, indicating potential gaps in foundational knowledge that may affect their calculations.
schattenjaeger
For this problem assume the "EM spectrum of astrophysical relevance" is between 1m and 10^-3nm. Calculate the fraction of the visible light by assuming a) a linear scale and b)a logarithmic scale. Explain the difference..
hur? I'm guessing this is one of those math skills I've either blanked on or never knew but should've, but as far as calculating the fraction goes I can only think to like divide the range of visible light(which is like 3 x 10^-7, right?)by the total range, which would be, pretty much, 1? (1-10^-12 to be exact)and then I spose that'd be pretty linear, or whatever.
So assuming that out of my ass speculation is right, I still don't know what to do with a logarithmic scale. I could take the log of that 3x10^-7 but that's a negative answer. I could piddle with the units so it wasn't negative, but that seems awfully...wrong. So primarily my question is a "what the hell am I doing?" problem.
And one quickie, it wants me to derive Wien's displacement law by setting (we'll make y be my lambda) dB/dy=0, where B is that 2hc^2etc./e^hc/kt -1 with the formatting kept poor just so you get the point. The problem only wants us to work it out to where we get something only solvable by numerical methods, then stop, so if I take the derivative of that and set it equal to 0, my next stop would be to solve for lambda*T, I guess, and it'd equal what it equals in the actual formula, would that be the step to stop at?
Astronomy news on Phys.org
Yep.
The logarithm of a number less than one is negative -- this is perfectly alright. Imagine I express the entire range of wavelengths in "log meter" units, meaning, for example, 1 cm is expressed as "-2" and 10-7 m is "-7". In this unit system, what is the range spanned by visible light? What is the range of the EM spectrum mentioned in the question?
Give it a try and see what you get. I suspect you won't be able to solve for [itex]\lambda T[/itex] or it wouldn't need to be done numerically.
Ah, ok, thanks!
So doing it like that for the logarithmic scale I got like 2 percent which sounds decent enough, as for the linear scale, since the length of the whole thing is just 1meter(unless I want to be just THAT accurate)is the percent 3x10^-5?(3x10^-7 *100 percent)?
Sounds good.
  • · Replies 105 ·
15K
  • · Replies 67 ·
17K
  • · Replies 29 ·
  • · Replies 39 ·
29K
