How Do Photons Influence Quantum Systems?
  • Context: Graduate
  • Thread starter Thread starter Ratzinger
    Photon
The discussion revolves around the nature of photons, particularly their behavior in quantum systems, including their energy, momentum, and localization in position space. Participants explore theoretical implications, semantic definitions, and the effects of superposition on photon states, as well as the emission characteristics of atoms.
  • Some participants assert that photons have well-defined momentum and energy, leading to uncertainty in position space.
  • There is a discussion on the implications of superposing momentum eigenstates and whether such states can still be considered "photons," with some arguing it is a semantic issue.
  • Concerns are raised about the definition of a photon when its energy is not well-defined, questioning if it can still be called a photon under such conditions.
  • Interactions involving photons and matter are described, with some participants noting that localization in position space affects the purity of the photon state.
  • Questions are posed regarding the emission of electromagnetic waves by atoms, specifically whether they emit superpositions of pure one-photon states rather than sharp frequencies.
  • A later reply discusses the uncertainty principle and coherence lengths of photons, emphasizing that emitted photons do not have definite energy and that their characteristics depend on the emission process.
Participants express differing views on the definitions and characteristics of photons, particularly regarding superpositions and energy definitions. The discussion remains unresolved with multiple competing perspectives on these topics.
Limitations include the dependence on definitions of photon states and the unresolved nature of how superpositions affect the characterization of photons. The discussion also touches on the implications of the uncertainty principle without reaching a consensus.
Ratzinger
Four more photon questions.
So photons are ‘particles’ in momentum eigenspace with (discrete, perfectly well-defined) momentum p and energy E= hf.
1. Does that definite energy translate into the complete uncertainty of the photon in the position space?
2. What happens when the momentum eigenstates are superposed? Doesn’t we have localized waves in position space now that correspond to a ‘size’ of a photon?
3. But when the well-defined energy is gone, are we still allowed to call it a photon?
Even if this the quantum world, wasn’t the definition of a photon its discreteness in energy space?
4. When a single photon interacts with matter (gets absorbed by an atom, hits a plate and
leaves a spot) , well-defined values of energy and momentum get transmitted. But are not these interactions (and so the photon) also precisely localized in position space?
thanks
Well,
they are actually bookkeeping units of the momentum/energy (P,H) eigenstates of the free quantum field.
Yes, because they correspond to the "classical modes" of the field. For instance, in EM they correspond to the harmonic plane waves. These fill all of space.
You can of course make superpositions of the eigenstates of (P,H), and these will be possible states of the quantum field. You can now argue all day whether or not you call such solutions "photons". It's really a semantic issue.
As I said, it is a semantic issue. I find it ok to call superpositions of 1-photon states also 1-photon states. Some object to that. Take your pick.
Well, the better they are localized in position space, the more "blurry" they are in "pure photon" space (or better, the more "neighbouring" pure photon states also have finite amplitude for the interaction). That's why I consider it a good idea to call a superposition of "pure" one-photon states also a 1-photon state. People are way less picky when it comes, for instance, to electrons. Are superpositions of pure energy and momentum "1-electron" states also "1-electron" states, or not ?
When atoms only emit EM waves in certain well-defined frequencies, how can we speak about blurry pure photon states?
Do atoms emit normally superpositions of pure one-photon states instead of sharp frequencies/ energies?
First question: recoil, thermal agitation, and radiative line broadening -- simply put, the excited states of an atom are not exact eigenstates of the atom-radiation system, and the are, metaphorically speaking, somewhat fuzzy. (This can be made quite rigorous,as was done by Wigner and Weiskopf.Their work is all over the place, particulalry in nuclear and particle physics, and, probably, Google) (It's another matter whether or not the various forms of line broadening are practically important.)
Second Question: vanesch gave all the info you need to answer this one by yourself.
Regards,
Reilly Atkinson
Thanks Reilly. Always learn a lot reading your posts.
I also found a lovely thread. It is called "Length of wavetrain of a single photon". http://www.lns.cornell.edu/spr/1999-02/threads.html#0014350
I wasn't able to read everything yet but it looks like a gold mine. Saw also Vanesch posting there.
Especially this post (http://www.lns.cornell.edu/spr/1999-02/msg0014640.html) is hitting the nail to my posted question. I hope no one minds if I quote it here.
Suppose an atom emits a photon by jumping from one quantum state to
another. The photon that's emitted does not have a definite energy.
Its energy is intrinsically uncertain, in accordance with (one version
of) the Heisenberg uncertainty principle. If you know enough about
the emission process, you can calculate the probability distribution
of energies. In particular, you can calculate the average value
(a.k.a. the expected value) of the energy. You can also calculate the
standard deviation of the distribution of energies, a quantity that is
usually called the "uncertainty" in the energy. You can't calculate
"the energy," because the photon doesn't have a definite energy.
Now, it's certainly possible to produce a bunch of photons that all
have the same average energy, but that are not all the same. In
particular, you can produce one photon with a pretty precisely
specified energy and another with a much less well-known energy. (Say
the first one has an energy of 1.000 eV plus or minus 0.001 eV, and
the second one has an energy of 1.000 eV plus or minus 0.1 eV.) Those
two photons will have the same average wavelength, but different
coherence lengths. (The coherence length is, more or less, the
physical extent of the photon's wavefunction -- i.e., how many
"wiggles" it has.) In particular, the photon with the
precisely-specified energy has a longer coherence length (more
wiggles) than the one with the vague energy. This is just a statement
of (one version of) the uncertainty principle.
You can, as a purely theoretical construct, consider a photon whose
energy is precisely specified: E = 1.000...000... eV, with
absolutely no uncertainty. A photon like that would have
an infinitely long coherence length (infinitely many wiggles).
Its wave function would be a sine wave, extending all the way
from x = - infinity to x = + infinity.
I know that you don't believe me about this. You think I'm lying, or
oversimplifying, or something. I don't know how to convince you I'm
not, except to repeat myself, and put the statement into a box
for good measure:
----------------------8<---CLIP-'N'-SAVE---8<------------------------
| A photon with a definitely-specified energy has a wavefunction |
| that is a literal, honest-to-god sine wave, extending from |
| x = literal, honest-to-god minus infinity to x = literal, |
| honest-to-god plus infinity. |
Now, a photon that is emitted by some realistic process (like an atom
jumping from one state to another) doesn't produce such a sine wave,
because it doesn't produce a photon of definite energy. It produces a
photon with some uncertainty in the energy, or in other words with
some finite coherence length. That coherence length depends on the
details of exactly how the photon was produced. For any given average
energy, you can imagine photons that have very long coherence lengths
or very short coherence lengths. Which one you get in any particular
situation depends on the exact details of the process by which your
photon was produced, which is why there's no single answer to the
question "how long is the wavetrain of a single photon."
Your statement above (the one that inspired this rant) is more or less
true, if you interpret "same energy" to mean "same definite energy."
Two photons that both have the same infinitely-precisely-specified
energy are the same (up to differences like direction of propagation,
phase, and polarization): they both look like pure, infinitely long
sine waves. But not all photons (in fact, no photons in the real
world) are emitted with definite energy, so this statement, while
true, isn't very helpful.
I have one more thing to clear. I apologize.
Reilly said 'the excited states of an atom are not exact eigenstates of the atom-radiation system'. So the blurrieness of E does not only stem from the fact that we don't know in which energy eigenstate the state will fall after measurement but also we don't know the exact eigenstates. Before measurement we are not only ignorant of if the photon comes from electron jumping 1, 2, 3 or 4, but also don't know exactly what kind of photons are produced by each individual quantum jumping.
Also, as has been said, photons of definite energy do not exist in the real universe.
So here my question: Is the inexactness of the eigenstates a (theoretical and empirical) necessity for systems that emit and absorb photons?
(As opposed to bound systems that don't radiate, like particle in the box.)
Because otherwise infinite long coherent length, i.e. unphysical photons.
thanks
Indeed, and they better don't be, because otherwise they could not go to the ground state. The point is that if two systems, S1 and S2, would have a hamiltonian H (of the combined system), such that its eigenstates take on the form of a product: |s1_e1a> x |s2_e1b> with eigenvalue E = e1a + e1b, then this would be a stationary state, and it could not evolve into something else. This would be the case, for instance, if H = H1 + H2 with H1 acting only on S1 and H2 acting only on S2. This is the case of non-interacting systems. If we take the eigenstates of H1, call them |s1_ena> and take the eigenstates of H2, call them |s2_emb> then the eigenstates of H take on the form |s1_ena> x |s2_enb>. And they are strict eigenstates (stationary states) of the overall hamiltonian. So they don't change over time.
However, if there is an extra interaction term: H = H1 + H2 + lambda H12 which couples both systems, then one could hope for |s1_ena> x |s2_enb> to be GOOD APPROXIMATIONS but not exact eigenstates of H. The fact that they are good approximations is that they are *almost* stationary states (in that we can "recognize" them as relatively stable states of the subsystems, and not as some wildly evolving random state). But they will "slowly" evolve because they are not strictly eigenstates.
This is why we can "recognize" the excited atom state as an "almost" stable state (and not some very chaotic random state of an atom) - it would be a stable state if we could switch off the coupling to the EM field - but we can't - - but why it finally IS NOT a stable state because it slowly evolves into other states. This is because of the interaction term H12, it is NOT a strict eigenstate of the overall hamiltonian.
So the initial state |excited atom> |vacuum field state> will not remain so, and will get a growing component with |ground state> |emitted photon>.
  • · Replies 38 ·
  • · Replies 23 ·
  • · Replies 0 ·
  • · Replies 16 ·
  • · Replies 58 ·
  • · Replies 41 ·
