How Does Earth's Atmospheric Charge Density Vary with Altitude?
The discussion focuses on calculating the volume charge density of Earth's atmosphere between altitudes of 271 m and 409 m, using electric field measurements of 155 N/C and 175.5 N/C, respectively. By applying Gauss' law, the charge density is derived as 1.11 C/m³. The calculations involve determining the electric flux and the area of a Gaussian surface, with the assumption of a uniform charge distribution and neglecting Earth's curvature. The permittivity of free space is utilized in the calculations, confirming the relevance of electrostatic principles in atmospheric studies.
  • Understanding of Gauss' Law in electrostatics
  • Familiarity with electric field concepts and units (N/C)
  • Knowledge of volume charge density calculations (C/m³)
  • Basic geometry of spheres and areas for Gaussian surfaces
  • Study the application of Gauss' Law in different geometries
  • Learn about the relationship between electric fields and charge density
  • Explore the effects of altitude on atmospheric electric fields
  • Investigate the implications of atmospheric charge density on weather phenomena
Physicists, atmospheric scientists, and electrical engineers interested in electrostatics and atmospheric studies will benefit from this discussion.
Punchlinegirl
In a particular region of the Earth's atmosphere, the electric field above the Earth's surface has been measured to be 155 N/C downward at an altitude of 271 m and 175.5 N/C downward at an altitude of 409 m. The permittivity of free space is 8.85 x 10^-12 C^2/Nm^2. Neglecting the curvature of the earth, calculate the volume charge density of the atmosphere assuming it to be uniform between 271 m and 409 m. Answer in units of C/m^3.
First I figured out the 2 equations for flux and set them equal to each other. [tex]\Phi = q_e_n_c / E_o[/tex] and [tex]\Phi = E cos \theta * A[/tex] Since theta= 90, cos 90=1, so it's just * A.
To find the area of the sphere, I took the area of the larger sphere and subtracted the smaller one.
so [tex]A= (E_R * 4\pi R^2)- (E_r * 4\pi r^2)[/tex]
So then [tex]q_e_n_c/ E_o = (E_RA- E_rA)[/tex]
q_enc= (E_RA- E_rA)*E_o
since it's charge per volume, you divide each side by the volume and solve for the charge.
so [tex]q_e_n_c = (E_RA - E_rA)*E_o / 4/3 \pi (R^3-r^3)[/tex]
i was a little unsure of what each variable was in the problem, but I think
E_r = 155 N/C
E_R = 175.5 N/C
r= 271 m
R= 409
So plugging in gives (155* 4pi (271)^2)=1.43 x 10^8 for E_rA
E_RA = (175.5 * 4pi (409)^2) = 3.69 x 10^8
so 2.26x 10^8/ (4/3)pi (409^3 -271^3)) =1.11 C/m^3
Can someone tell me what I'm doing wrong?
We are asked to neglect the curvature of the earth. So, consider a large, flat region of the Earth's surface. Imagine a Gaussian surface in the shape of a rectangular box with the top and bottom surfaces of the box parallel to the ground. Let the top surface of the box be 409 m above the ground and the bottom surface of the box be 271 m above the ground. Let the top and bottom surfaces of the box each have area ##A##.
Gauss' law can be used to find an expression for the total charge ##Q## inside the box. The expression will involve the area ##A##.
Then we can derive an expression for the charge density ##\rho## and find that the area ##A## does not appear in the expression for ##\rho##.
