How to Calculate and Measure Electrical Forces: Point Charges Problem 22
The discussion focuses on calculating the resultant electrical force on a charge of 1.8*10^-9 C due to two positive point charges of 1.9*10^-9 C each, positioned symmetrically at y=0.38m and y=-0.38m. The user initially miscalculated the resultant force by incorrectly summing the forces without considering vector components. The correct approach involves using Coulomb's law and vector addition to find both the magnitude and direction of the resultant force, leveraging symmetry for simplification.
  • Coulomb's Law for electric forces
  • Vector addition of forces
  • Trigonometry, specifically sine and cosine functions
  • Understanding of point charges and their interactions
  • Study Coulomb's Law in detail, including its mathematical formulation
  • Learn vector addition techniques for forces in physics
  • Explore trigonometric functions and their applications in physics problems
  • Investigate symmetry in electric fields and forces for simplification
This discussion is beneficial for physics students, educators, and anyone interested in understanding electric forces and vector analysis in electrostatics.
mustang
Problem 22.
Two positive point charges, each of which has a charge of 1.9*10^-9C, are located at y=0.38m and y=-0.38m.
a. Find the magnitude of the resultant electrial force on a charge of 1.8*10^-9 C located at x=0.28m. Answer in N.
Note: I used a^2+b^2=c^2 to find r in Coluomb's law which I got as 0.472016949. From that I added F_1+F_2 to get 0.0000000276N which was wrong, what did I do wrong?
b. What is the direction of this force(measured from the positive x-axis, with counterclockwise positive)? Answer in degrees.
Note: Would I find the angle by dividing the two electric force answers and times by tan-1?
No, you should, in general, use the fact that a vector, of length v, making angle θ with the x-axis has x-component v cosθ and y-component v sinθ then add the two vector component wise.
Another way is to use the sin law in the triangles formed.
Actually, in this case, the answer is very simple: since the charges are the same and are symmetrically placed, use symmetry.
Answer
I need more help?
