What is the magnitude of the repulsive force in a nuclear fission problem?
  • Thread starter Thread starter mustang
    Fission Physics
The magnitude of the repulsive force in a nuclear fission problem involving a 235_U nucleus is calculated to be approximately 5.83*10^-8 N. This force arises when the nucleus divides into two smaller spheres, each containing 46 protons and a radius of 5.9*10^-15 m. The calculation employs Coulomb's Law, utilizing Coulomb's constant (8.99*10^9 N*m^2/C^2) and the charge of each sphere, which is derived from the number of protons multiplied by the elementary charge (1.6*10^-19 C). The distance between the spheres is determined to be 1.18*10^-14 m, based on the sum of their radii.
  • Coulomb's Law
  • Elementary charge (1.6*10^-19 C)
  • Understanding of atomic structure (protons and atomic number)
  • Basic algebra for force calculations
  • Study Coulomb's Law in detail to understand its applications in electrostatics.
  • Explore the concept of nuclear fission and its implications in nuclear physics.
  • Learn about the properties of protons and their role in atomic structure.
  • Investigate the significance of Coulomb's constant in various physical scenarios.
Students and professionals in nuclear physics, physicists working on nuclear reactions, and anyone interested in the fundamental forces at play in atomic interactions.
mustang
Problem 19.
At the point of fission, a nucleus of 235_U that has 92 protons is divded into two smaller spheres, each of which has 46 protons and a radius of 5.9*10^-15m. what is the magnitude of the repulsive force pushing these two spheres apart? Use 8.99*10^9 N*m^2/C^2.
Note: How can you find the distance if the problem only the radius?
I would assume the two spheres are meant to be touching each other so that you can assume to point charges separated by 2(5.9*10^-15m)=
11.8*10-15m.
The magnitude of the repulsive force in this nuclear fission problem can be calculated using Coulomb's Law, which states that the force between two charged objects is directly proportional to the product of their charges and inversely proportional to the square of the distance between them.
In this problem, we can calculate the charge of each smaller sphere by using the fact that the number of protons in an atom is equal to its atomic number. So each sphere has a charge of 46 protons, or 46 times the elementary charge (1.6*10^-19 C).
Next, we need to find the distance between the two spheres. While the problem only gives us the radius of each sphere, we can use the fact that the distance between two spheres is equal to the sum of their radii. So in this case, the distance between the two spheres would be 2*5.9*10^-15m, or 1.18*10^-14m.
Now, we can plug these values into Coulomb's Law:
F = k * (q1 * q2) / d^2
Where k is the Coulomb's constant (8.99*10^9 N*m^2/C^2), q1 and q2 are the charges of the two spheres, and d is the distance between them.
So the magnitude of the repulsive force would be:
F = (8.99*10^9 N*m^2/C^2) * [(46 * 1.6*10^-19 C) * (46 * 1.6*10^-19 C)] / (1.18*10^-14m)^2
F = 5.83*10^-8 N
Therefore, the magnitude of the repulsive force pushing the two spheres apart in this nuclear fission problem is approximately 5.83*10^-8 N.
