Thread Closed
Modern Physics-HELP 911!
Share Thread Thread Tools
Jan31-06, 11:06 PM   #1
My problem is that I am required to derive such formulae, which are:
MEASUREMENT of the LASER wavelength.
(1) 1 or lamda = 2* dm/m & (2) m=(n-1) ( 2*d/1)*(Dp/ Patm)
dm= distance of the movable mirror moved toward a beam splitter.
m= no. of fringes that cross a given reference point.
Dp = Pressure(final)- Pressure(initial)
d= distance of the vacuum air cell that was used upon experiment to generate fringes
Patm= atmospheric pressure=760atm.
I would appreciate any help deriving these formulae in step by step way.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Feb1-06, 07:58 AM   #2
Recognitions:
Homework Helper Homework Help
A monochromatic beam (1) entering from the left splits up at B, a half silvered mirror, into two beams (2) and (3) and is reflected back by two mirrors. Beam (2) continues onwards to O and on its return (3) is reflected downward also to O (part of both beams actually since the mirror is half silvered). At O the beams are combined optically resulting interference of the two beams. If the paths of the two beams , (2) and (3), are the same length constructive interference will result at and a bright fringe will be observed at O. If the movable mirror is moved [itex]\frac{\lambda}{4}[/itex] closer to the beam splitter this condition will change to destructive interference. If the mirror is moved by [itex]\frac{\lambda}{2}[/itex] one fringe change will be observed at O. This gives you your first equation.
Thread Closed
Thread Tools
Similar Threads for: Modern Physics-HELP 911!
Thread Forum Replies
modern physics Academic Guidance 10
Physics department faculty advisor said Modern Physics will be hardest course Academic Guidance 7
modern physics Academic Guidance 4
modern physics Introductory Physics Homework 1
