Normal coordinates (small oscillations)
The discussion revolves around the problem of small oscillations in a 3-atom molecule, specifically CO2, modeled with masses and springs. Participants are examining the normal coordinates associated with different modes of oscillation, particularly focusing on the mode with zero frequency, which corresponds to the rigid translation of the molecule.
  • Conceptual clarification, Assumption checking, Mathematical reasoning
  • The original poster attempts to derive normal coordinates for the oscillation modes and compares their results with a reference from Goldstein's "Classical Mechanics." Participants question the dimensional consistency of the solutions and the meaning of normal coordinates.
The discussion is ongoing, with some participants expressing doubt about the correctness of the original poster's solution. There is a focus on dimensional analysis and the implications of different normalization methods. The original poster has reiterated their approach and is seeking further clarification on the discrepancies noted.
Participants are navigating differences in solutions and interpretations of normal coordinates, with an emphasis on ensuring dimensional correctness. The discussion reflects a lack of consensus on which solution is more valid, highlighting the complexities involved in the analysis of normal modes.
Chen
Hello,
I solved the problem of small oscillations for a 3-atom molecule, such as CO2, which is modeled as 3 masses connected by 2 springs. Both springs have a constant k, the outer masses are m and the middle one is M.
There are 3 modes of oscillations, and one of them is of course [tex]\omega[/tex] = 0, i.e it is a rigid translation of the molecule as a whole. I've also found the normal coordinates for each mode, and for this particular one I found:
[tex]Q = \frac{1}{\sqrt{2m+M}} (mq_1 + Mq_2 + mq_3)[/tex]
Where qi is the "real" coordinates of each molecule. This seems pretty logical, right? Because basically I foud that the normal coordinates for the [tex]\omega[/tex] = 0 mode is exactly the coordinate of the center of mass (after normalization).
However, the exact same problem was solved in Goldstein's "Classical mechanics" (3rd ed.), and a different normal coordinate was found there. It was:
[tex]Q = \frac{1}{\sqrt{2m+M}} (\sqrt{m}q_1 + \sqrt{M}q_2 + \sqrt{m}q_3)[/tex]
Which is not what I found, nor do I understand its meaning. My friend thinks that both answers are correct, and the difference is just in normalization; I don't agree, one of these answers must be wrong. I'd think that my answer is correct, but since the other one is taken for the book, I'm not so sure.
Can someone please clarify? Which answer seems more logical?
Thanks,
Chen
Dimensionally speaking only one of those solutions can be correct. Yours differs by [itex]\sqrt {m}[/itex]. I doubt there is a dimensional error in Goldstein.
Double check your solution.
Actually it is clear that yours is incorrect.
Well, suppose that in my solution I divide by (2m+M) and not its square root, so the dimensions are not a problem. It still makes more sense than the solution in Goldstein, no? Because it's the coordinate of the center of mass. So unless I don't understand the meaning of a normal coordinate, I'd think it looks pretty right.
I double- and triple- checked my solution many times. I diagonalized V (potential energy) over T (kinetic energy), and found that the diagonalizing matrix A, such that [tex]A^{-1}VA = I[/tex] is:
[tex]A = \left(\begin{array}{ccc}\frac{1}{\sqrt{2m+M}}&\frac{1}{\sqrt{2m}}&\frac{M}{\sqrt{2mM(2m+M)}}\\\frac{1}{\sqrt{2m+M}}&0&\frac{-2m}{\sqrt{2mM(2m+M)}}\\\frac{1}{\sqrt{2m+M}}&\frac{-1}{\sqrt{2m}}&\frac{M}{\sqrt{2mM(2m+M)}}\end{array}\right)[/tex]
Which is orthogonal over T, i.e [tex]A^tTA = I[/tex]. This is also the matrix that appears in Goldstein. Therefore, the normal coordinates are:
[tex]\vec{Q} = A^{-1}\vec{q} = A^tT\vec{q}[/tex]
Where T is the trivial matrix, with simply m, M, m on the diagonal.
Now you see how I came to my solution?
I don't suppose you could explain why that is?
Thanks,
Chen
Anyone?
Chen
