Proving 2^(2^n) + 1 Ends in 7 for All n > 1 - Induction Question
  • Thread starter Thread starter Kamataat
    Induction
The discussion revolves around proving by induction that the expression 2^(2^n) + 1 ends in 7 for all n > 1. The original poster presents an initial case for n = 2 and explores the last digit of the expression.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • The original poster attempts to establish a base case and uses induction to show that if 2^(2^k) ends in 6, then 2^(2^(k+1)) also ends in 6, leading to the conclusion that 2^(2^n) + 1 ends in 7. Other participants affirm this reasoning and suggest alternative formulations of the argument.
The discussion appears to be progressing with participants validating each other's reasoning. Some participants offer different perspectives on how to frame the induction step, but there is no explicit consensus on the finality of the proof.
Participants are working under the assumption that the property holds for n > 1, and there is a focus on the last digit of the expressions involved. There is a brief diversion from the topic in one post, but the main discussion remains centered on the induction proof.
Kamataat
Prove by induction that [tex]2^{2^n}+1[/tex] always ends in 7 for all n > 1 (true for n = 2).
I couldn't figure out anything to do with the last digit being 7, so I looked the case that [tex]2^{2^n}[/tex] ends in 6 for all n > 1, which is also true for n = 2.
Suppose it's true for n = k:
[tex]2^{2^{k+1}}=2^{2^k\cdot 2}=(2^{2^k})^2[/tex]
Now, since by assumption [tex]2^{2^k}[/tex] ends in 6, its 2nd power also ends in 6 since 6x6=36. Hence [tex]2^{2^n}+1[/tex] ends in 7 for all n > 1.
Correct or not?
Thanks in advance,
- Kamataat
Yes, that's perfectly good. Obviously n+ 1 will end in 7 if and only if n ends in 6.
You could, just as easily, say "Suppose [itex]2^{2^k}+1[/itex] ends in 7 for some k. Then [itex]2^{2^k}[/itex] ends in 6. Therefore, [itex]2^{2^{k+1}}= (2^{2^k})^2[/itex] also ends in 6 and so [itex]2^{2^{k+1}}+ 1[/itex] ends in 7".
I think what you've done is correct. Here is how I would set it out. I'm not sure if it's correct though.
Base case, assume true for n = so that [itex]2^{2^k } \equiv 6\left( {\bmod 10} \right)[/itex]
Using the hypothesis:
[tex] 2^{2^{\left( {k + 1} \right)} } \equiv 2^{2\left( {2^k } \right)} \equiv \left( {2^{2^k } } \right)^2 \equiv \left( 6 \right)^2 \equiv 6\left( {\bmod 10} \right)[/tex]
I think the result follows from that.
Oops. Stumbled into the wrong thread. Though it was about labour & delivery. Please continue...
  • · Replies 23 ·
